Idle problem is back
Old Mar 11, 2007 | 01:13 PM
ericgutz's Avatar
Default Idle problem is back
My idle problem is back again. When i start up the car, it seems like it's not getting enough umph. Last time this problem happened, i messed with the air filter on the CAI and the problem went away. No such luck this time.
Even with the air filter off, the car will only stay on if i give it some gas to keep the RPM above 600. If i release the gas pedal, the car stalls out.
Any ideas?
Old Mar 11, 2007 | 01:37 PM
take your filter off your CAI and clean it. K&N makes a filter recharge cleaning kit for about 10 bucks. Youll also want to pick up some mass air flow sensor cleaner. it comes in an aeresol can and should be somewhere in the same area.
does the car throw a code at all? is your car tuned with a handheld?
Old Mar 11, 2007 | 02:09 PM
ericgutz's Avatar
How do i clean the MAF? Do i take off that portion of the CAI and just spray the cleaner through?
I don't think the filter is the problem, because the idle problem is still present when i remove the air filter.
No, the car is not putting out any codes and is not tuned with a handheld.
I've had this CAI for 3 or 4 years and never had any problems until i replaced the old MAC air filter with a K&N one a couple months back.
Old Mar 11, 2007 | 02:18 PM
thats probably why you are having problems. k&n filters are garbage and over-oiled from the factory. i can tell you theres probably oil and dirt on your mass air flow sensor causing faulty readings.
clean and reoil your filter lightly and clean the mass air flow sensor. pull it off and spray the mass air flow cleaner in the sensor and let it air dry off and spray it a couple times to get everything out.
Old Mar 11, 2007 | 02:58 PM
Yep, probably have a dirty MAF.
Old Mar 11, 2007 | 03:30 PM
ericgutz's Avatar
Alright, i've got the air filter and MAF off. Gonna clean & re-oil the filter and spray out the MAF.
Taking off the MAF reminded me of how annoying putting the CAI on was. One of the bolts holding on the fenderwell part was being a pain in the ***.
Let you guys know how it goes after i clean these things out and let them air dry for a couple of hours.
Old Mar 11, 2007 | 10:01 PM
ericgutz's Avatar
Okay, stang seems to be working now....... We'll see how it starts up in the morning.
I cleaned and re-oiled the air filter, cleaned the MAF with CRC MAF cleaner, and cleaned the throttle body with CRC throttle body cleaner.
Started the car and it worked a little better, but not much. Figured i'd take it for a drive and see if it ran better after a few miles of running it. The car needed gas, so i put in about 1/4 can of Seafoam with a full tank of gas.
Then i got on the freeway and after a few miles, it seemed to be running much better. Then i slowed to about 45mph and floored it to 100mph a few times to try and clean out any gunk. Would like to have gone faster and done this a few more times, but there's way too many police on the freeways out here in VA beach.
Anway, i'll let you guys know if this problem is really fixed after i drive to and from work tomorrow. Thanks for the help.
Old Mar 12, 2007 | 11:54 AM
ericgutz's Avatar
Stang ran great to and from work today.
Sounds like you guys were right about the K&N coming over-oiled from the factory and getting the MAF dirty.
Hopefully this is the end of this problem. And i know in the future to clean and oil any new K&N airfilter myselfe before installing it.
Icefreezen
Apr 13, 2010 02:46 AM
machnjo
Jun 27, 2007 07:52 PM
ericgutz
Apr 18, 2007 02:17 PM
Shambles
Oct 16, 2005 02:34 PM
drewbhot
May 25, 2005 08:39 AM
