question about pi intake and cams
Old Mar 10, 2007 | 12:07 PM
ex-ricer98gt's Avatar
Default question about pi intake and cams
hey i just have a couple questions, i have a 98 gt, i also have a set of windsor cams from a 00 and intake from a 03, now what exactly are all the parts i need to swap all this? and how much would i cost to get it installed? i called this 1 place around my house and they said they want a 1000 for it
my ultimate goal is run mid 12's with cams, intake, drag suspension, built auto tranny, and good dyno tune
Old Mar 11, 2007 | 10:05 AM
intake gaskets, head gaskets, head bolts, drill and tap intake crossover for 2nd coolant temp sensor.
1000 bucks isn't a bad price. It's a full days job. Don't think you'll make mid 12's until you've got ported heads, higher compression, 4.30 gears, and a 125 shot of nitrous.
Old Mar 11, 2007 | 10:10 AM
why would i need head bolts and gaskets? im just swapping the cams and intake
Old Mar 11, 2007 | 10:13 AM
thats if you're doing the heads too. I'd do the heads with some ported ones for all the money you'll spend for the install. (I misread your original post and thought you were doing the heads too). You may want some adapter plates for the intake from HPS if you don't do heads too.
Old Mar 11, 2007 | 11:21 AM
i was thinking about doing the heads also, but a port job from mmr would be about 700 plus install for the heads couple hundred so h/c/i instal would be around 1500-2000? i should save for it, would be better in the long run
Old Mar 11, 2007 | 05:48 PM
save your pennies and go big the first time. Saves you money in the long run.
330CubeGt
Mustang Classifieds
Mar 8, 2010 10:35 PM
krazedcraka09
Oct 11, 2009 05:54 PM
majik_420
16
May 5, 2007 07:33 AM
super96stang
Mar 4, 2007 12:59 PM
Caseych
Oct 28, 2006 11:21 AM
