Took it to advance this morning
Old Feb 25, 2007 | 07:44 AM
03_GT's Avatar
Smoke Tires....Not Drugs.
Default Took it to advance this morning
And i had them hook a computer up to the mustang and it says that cylinder 4 and 8 are misfireing, So how can i fix this now?
Old Feb 25, 2007 | 07:57 AM
You need to know hy it is miss-firing. Either those cyclinders are getting fuel or spark? I would start by checking those plugs and by checking the coil packs.
Old Feb 25, 2007 | 09:22 AM
switch the coil packs from 2 other cylinders and have it re-tested. If it fails on the new cylinders then it's coil packs. If not, try spark plugs and possibly those two injectors.
Old Feb 25, 2007 | 10:27 AM
Old Feb 25, 2007 | 11:25 AM
03_GT's Avatar
I just got done cleaning everything (coil packs, spark plugs, and the injectors)
And now the service engine light went off The car runs alot better then it did from last night, but it still sputters here and thier.
Old Feb 27, 2007 | 08:31 AM
Wheat's Avatar
Take another look at the rubber boots on the coils; a tiny pinhole can cause this, you may see a small, chalky white area where the spark has jumped through.
Old Feb 28, 2007 | 05:55 AM
Your EGR can fail also; i had this happen to my car and it only gave misfire codes on two cyclinders. But i would be more willing to guess spark or fuel related for you. Mine went froma coolant line that blow and destroyed some wiring to the egr valve that stayed open all the time.
Old Feb 28, 2007 | 06:16 AM
you'll need to replace the 2 COP's (maybe more, once you disturb them) and proby should put in 8 new plugs. cleaning is a waste of time, esp injectors as FoMoCo has used deposit resistant fuel injectors since @1992
Old Feb 28, 2007 | 07:57 AM
03_GT's Avatar
Everything is working right, after i cleaned everything the service engine light shut off and the engine is not misfiring anymore!
bigkeeko
May 8, 2011 04:17 AM
seancolon
Nov 4, 2007 08:44 AM
ace1_15
Oct 7, 2006 08:50 AM
Apr 18, 2005 03:42 PM
PistolWhip
Apr 15, 2005 02:27 PM
