Urethane engine/trans bushings, are they worth it?
Old Feb 19, 2007 | 01:39 PM
Mirage775's Avatar
Default Urethane engine/trans bushings, are they worth it?
I was planning on also installing some urethane engine/trans/trans x-member to frame urethane bushing later on in my 93 GT. Would I benefit from replacing the rubber with urethane or not?
Old Feb 19, 2007 | 09:12 PM
ClemsonStang's Avatar
the poly ones last longer, but they are stiffer, they let more of the shock and vibrations come back through the car. my drive shaft is a little out of balance and the poly tranny mount lets more of the interstate vibrations come though the car. th engine mounts let the harder idle shake the car a tiny bit more. but i also added a tubular kmember, aarms, and coil overs at the same time, so it changed a lot.
Old Feb 19, 2007 | 09:37 PM
3V2000GT's Avatar
46MONSTER
i have urathane motor mounts and they much stiffer, I find that at high speeds if i leave it in gear the car shakes more, because the the stiffer mounts transfer the vibrations through out the car more. the mounts eliminate engine flex and allow a transfer of a little more power to the wheels, but not much.
Old Feb 20, 2007 | 03:45 AM
Mirage775's Avatar
I'd heard that the poly ones transferred more power to the rear wheels. And I figured that there was gonna be some added firmness/stiffness, but the way yall talk, it sounds like too much for my taste? I mean, the Mustang or Fox body is one of the stiffest, from the factory cars I've ever drove. I might do the tanny poly and replace the engine ones with rubber?
Old Feb 20, 2007 | 06:58 AM
A good compromise is to use a torque strap or to do a redneck style poly mount. Basically, you drill through the rubber mount and put a bolt through it and tighten it w/ a nut. You can then decide how stiff you want it by how tight you make the bolt. However, the poly mounts shouldn't scare you away since they are no where near what solid mounts will do.
Old Feb 20, 2007 | 10:17 AM
your kidding right? man its really not that bad. its a fox mustang, its gonna be alittle loud, make some noise, and vibrate. its part of the fun of driving a 15 year old car. mines noisey and creaky. the poly mounts really arnt that bad to be honest, imo.
Old Feb 20, 2007 | 05:21 PM
Mirage775's Avatar
Yes, the car is a stiff ride, but I wasn't complaining about it or if it sounded like I was, I didn't mean too? Here's how I see it, it's all engine and a small, short 2 door, sports car, it's supposed to ride like ****, they're not made to be comfy It's just the way yall were talking, sounded like urethane engine/trans mounts made it a lot worse than it is now? That's what I said what I said...
Old Feb 21, 2007 | 05:13 AM
i dont think it does. im not much help because i also added coil overs and changed the whole front and rear suspension. poly mounts shouldnt be too bad.
Old Feb 21, 2007 | 03:46 PM
I have them and you can feel the motor a bit more but thats the nature of the beast.
Old Feb 22, 2007 | 07:16 PM
SleepingGT's Avatar
i found out today that poly's are needed...i tore my stock transmission mount completely in to....energy trans mount is in the mail right now
spike_africa
75
Jul 22, 2010 04:42 PM
Mirage775
Feb 26, 2007 02:55 PM
3V2000GT
Oct 22, 2006 07:46 PM
sbrooks
38
Oct 12, 2006 04:12 AM
xxplatzxx
Jun 21, 2005 05:28 AM
