Lca
Old Jan 31, 2007 | 06:17 PM
Chasinsparks's Avatar
Default Lca
I'm sure this has been addressed many times but, I looking for recomendations on LCA's and the need for UPPER control arms right now I can't plant the rear end, I know LCA's are in the future what brands are reccomended and do I need Upper's money is not a problem so I don't need the el cheapos
Next question how difficult is the installation, it does seem that hard I'm mechanically incline but recent had rods in my back, if there is any tips or tricks please advise
Old Jan 31, 2007 | 07:43 PM
all lower boxed control arms are the same. Get the cheapest that are boxed and have polly bushings. Install can by done by one person in ruffly 1-2 hours its a simple matter of unbolting then dropping them down one side at a time (so the spring doesnt fly out) and then installing new ones and jacking them up into place.
Old Jan 31, 2007 | 09:51 PM
Well what exactly are you looking for in a LCA? How much power are you putting down? What are your 60ft times? Is this a street/ strip car, mostly strip, DD?
Old Jan 31, 2007 | 10:15 PM
I think the best bang for the buck control arms are from UPR.
Old Feb 5, 2007 | 02:19 PM
the best arm is going to depend on your specific needs. Since you're having trouble planting the rear end I'm going to guess you hit the track regularly and you want better launches on an improved surface.
I'd generally start with a set of Maximum Motorsports drag race RLCA's with adjustable spring perches, poly front bushings and spherical axle end bushings. A MM panhard bar, a set of subframe braces (any ol') and a set of boxed FRPP uppers. You can get into adjustable uppers but it's really more hassle than it's worth unless you already know how to adjust them properly for a particular effect.
Oh yeah... and answer 03GTmustangs ?.
Old Feb 5, 2007 | 03:38 PM
Thanks for the Replys Jason at Steen Racing has it right now, doing Stage II Heads, Cams long tubes and blower, he is setting it UP with control arms and Subframe connectors he said trust him he'll have it set when I pick it up
Old Feb 6, 2007 | 06:53 AM
you should be in good shape then.
steve-o
Jul 18, 2006 09:09 AM
Apr 23, 2006 06:48 PM
floppy
Jan 27, 2006 03:06 PM
Dec 23, 2005 07:00 AM
WaterDR
Nov 3, 2004 09:35 AM
