Does the Variable Valve Timing only exist in the V8?
Does the Variable Valve Timing only exist in the V8? It seems that the Variable Valve Timing only exist on the current V8. Did the last gen 16 valve version have it?
Does it make the engine easier to rev?
But since I like to race here is the downside of VCT.......
If the cam keeps the valves open for longer periods of time, as with a racing cam, problems start to occur at the lower engine speeds. This will cause unburnt fuel to exit the engine since the valves are still open. This leads to lower engine performance and increased emissions. Basically it's crap if you plan to do anything internally to the engine. Personally I couldn't have a car that adjusted the timing for me. I would want it tuned and to stay the same way.
Variable Camshaft Timing (VCT) is an automobile variable valve timing technology developed by Ford. It utilizes electronically controlled hydraulic valves that direct engine oil into the camshaft phaser cavity. These oil control solenoids are bolted into the cylinder heads towards the front of the engine near the camshaft phasers. The powertrain control module (PCM) transmits a signal to the solenoids to move a valve spool that regulates the flow of oil to the phaser cavity. The phaser cavity changes the valve timing by either advancing or retarding the camshafts to allow for optimum engine performance, reduced emissions, and increased fuel efficiency. VCT effectively replaces the external Exhaust Gas Recirculation (EGR) system.
Variable camshaft timing was a key in the quest to wring more power from the Mustang’s 4.6-liter, three-valve MOD V-8 engine, while simultaneously improving efficiency and reducing emissions. VCT lets allows the valves operate at optimum points in the combustion cycle, tailored to the engine’s speed and load at that instant. Simular to the Honda VTEC
The VCT system is used in Ford's Triton 5.4L 3-valve V8 engine; the Australian Barra 182 and 240 Inline-6s; Ford's 4.6L 3-valve V8 engine used in the 2006-present Ford Explorer and 2005-present Ford Mustang GT; and the 2.0L Zetec Inline-4 used in the 1998-2003 Ford Escort ZX2, 2000 Ford Focus and 1995-2000 Ford Contour/Mercury Mystique.
Mirage775
Feb 16, 2007 06:34 AM
