Drive Shaft Hitting Floor Board?
Old Jan 17, 2007 | 11:17 AM
Slither's Avatar
Zig *hearts* Fishy
Default Drive Shaft Hitting Floor Board?
Ok so starting Sunday when I take off and get on it pretty good, the drive shaft hits the floorboard under my center console. The bracket is fine because I sat with the brakes on and got on the gas and it did nothing. It is only if I turn sharp and get on the gas or if that rear hits a pretty bad bump. Any ideas what could cause this?
Old Jan 17, 2007 | 11:25 AM
have you lowered your car? did you remove the damper from around the center section in the rear? did you change to an aluminum driveshaft?
Old Jan 17, 2007 | 11:32 AM
Slither's Avatar
Zig *hearts* Fishy
The car was lowered last April. I haven't taken anything off. I got it up on a life and did not see anything wrong or broken. The only thing that I did see was the isolator on the right rear spring was coming apart a little. I wouldn't think something that small would make the drive shaft start hitting though?
Old Jan 17, 2007 | 11:40 AM
Get under your car and see if the drive shaft can be moved up and down. basically see if theres any slack.
Old Jan 17, 2007 | 11:44 AM
yup, that could do it. also look at the top spring isolator and see if it's comming apart to
Old Jan 17, 2007 | 12:00 PM
Check your tranny bushing too. If it's shot, it could let the engine torque the trans/driveshaft as it pleases.
Old Jan 17, 2007 | 12:27 PM
Slither's Avatar
Zig *hearts* Fishy
Drive shaft was firm. Pushed up and down on it and it didnt move
Old Jan 17, 2007 | 12:48 PM
I'm going to say tranny bushing. I've seen worn/broken U joints do it too.
Steve@CJPP
Sponsors
Nov 7, 2012 08:06 AM
Brontobyte
Mar 11, 2010 05:01 PM
stang01
Apr 15, 2008 06:38 PM
TJeffer3
Nov 20, 2007 09:31 PM
00blkstanggt
Apr 23, 2006 02:54 PM
