Pictures Pictures of cars or pictures related to cars.
My winter project...
Old Jan 17, 2007 | 09:26 AM
ClemsonStang's Avatar
Default My winter project...
bought the car august 15th, 2006, went to college the 18th of august. put a clutch in it a weekend in the semester. drove it home tues the 12th. **** start weds the 13th
this is how the car started:
pulled the rear end out first, it already had 3.73s in it, but they were set up horridly and worn worse then you could beilive. put new 3.73s in it, rebuilt the track-loc with kevlar clutches. did the 5 lug conversion.
Old Jan 17, 2007 | 09:27 AM
sent the rear end off to be rebuilt and started on the next item on the list.
i dont like old alphebet cams either, but it was cheap. also put these on too:
Can you guess what this is for?
Old Jan 17, 2007 | 09:28 AM
thats right, it does this:
so i could remove this:
put a melling standard volume pump, arp pump shafter, and resealed the leaky pan gasket. you dont see the bottom of your motor that often do ya?
did i mention this was going on?
upr chromoly kmember kit. with these
and these
this is where i ended up
heres a good shot with the poly motor mounts
Old Jan 17, 2007 | 09:29 AM
got the rear end back, got it in the car and such, forgot to order new spring isolators. so i through the wheels i got for it onto the rear, and jacked the rear up to see roughly what it looks like.
not bad for an 18 year old and his dad in the driveway eh?
Old Jan 17, 2007 | 09:30 AM
got the control arms on
got the spindles on, had to run to Lowes to get some washers to use a spacers for the ball join bolts.
Ran into a problem, no one told me i HAD to run CC plates with coil overs, with that being said, im looking for a used set local. ive heard the post office will be closed tues as well. which is just going to slow me down a lot, but i have a lot of motor to put back together.
heres the old kmember, had to get the Aarm bolts off of it, the old Aarms and spindles are there too, as are the SN95 spindles that were on my spindles. you can also see the new tires that will go on middle of the week too.
heres pretty much the finished up rear. fogged the control arms black, new black poly spring idsolators, and new shocks.
Old Jan 17, 2007 | 09:31 AM
heres the coil overs and 99+ gt dual piston calipers.
CC plates
Old Jan 17, 2007 | 09:32 AM
rear wheels fit just about perfect!
fronts... not so much.
Old Jan 17, 2007 | 09:34 AM
got the motor back together, got it fired up and it was way off time, filled it full of coolant and went to time it but coolant was pouring out the front of the intake. i went to college and dad pulled it all apart last night, basically lower intakes cracked where the big steel water lines go in for the heater core. so im looking for a lower intake for a edllbrock performer or typhoon intake. or a really cheap stocker to get me by. got a good trade offer for the front bogarts... more updates as i have them.
Old Jan 17, 2007 | 10:19 AM
DarkSith's Avatar
Victory Is Mine
All that looks pretty sweat man, I'm a little envious though, I wish I had a fox mod like crazy.
Old Jan 17, 2007 | 11:47 AM
StormsGT's Avatar
1320 Number of the beast
Got to love the fox. Sweet car.
Old Jan 17, 2007 | 12:00 PM
madmatt's Avatar
Traitor...lol
Congrats! Looks great, and its coming together nicely!
Old Jan 17, 2007 | 01:50 PM
well i made a trade with someone. gonna trade my front bogarts with tires and lugs for a full set of FR500's black 17x9's for the front and 18x10's for the rear. looking to scrounge up some used tires to stuff on them.
Old Jan 18, 2007 | 06:35 PM
madmatt's Avatar
Traitor...lol
Sweet!
Old Jan 18, 2007 | 07:02 PM
Woooot thats a nice fox thats going to be when your done.
Old Jan 18, 2007 | 08:15 PM
well quick update, sunday im going to get the FR500's. until then im going to take care of a few things on the car. dads going to pull the front of the motor apart and check the cam timing to make sure its right. the timing looks to be close, but its not running like it at all. so while im at school next week hes going to be doing that.
i found a fender lip roller to borrow, and i think a set of front tires. i need to beat the rear inner fenders in and roll all 4 lips. i think ifound a set of front tires, but rears are going to be pricey. ill snap some pics of the car tomorrow sitting on all 4s, ireally wanna keep the rear bogarts around and find a set of fronts for the car later.
update tomorrow maybe.
Old Jan 18, 2007 | 09:11 PM
looks great so far.
Old Jan 19, 2007 | 05:24 AM
AREA 51's Avatar
awesome project. I want to see more now, dont sleep. Hurry up and finish it LOL
Old Jan 19, 2007 | 11:32 AM
lol, well we moved last weekend, most the heavy house stuff got moved. but sunday most of the heavy garage stuff will be moved. tool boxes, compressor, all the tools and such will come over as well. so thats going to be the next big step. dad will be working on it some this weekend, as will i. right now the big hurdle will be getting the motor apart and back together. and finding a set of cheap used rear tires. looking for 285/30/18's... not easy. think i found a cheap/free stock intake so thats good. then will have to trailer the car to the alignment shop because it is so far off.
Old Jan 19, 2007 | 06:07 PM
wade95's Avatar
Dude, great pics! +1 for us driveway mechanics!!! Im finishing up a project myself,,here's where I am currently:
BTW: What did you end up doing w/those Thunderbird wheels?
Old Jan 21, 2007 | 09:04 PM
I have wheels!!!!
Old Jan 21, 2007 | 09:05 PM
i traded my front bogarts/tires/lugs for a set of 4 brand new fr500's with lugs, locking lugs, and valve stems. guy from americanmuscle.com. he came down from philly and we met in mcdonald NC.
fronts are 17x9, and barely clear the coil overs, i wont know if they fit inside the outer fender till i get tires and get the car aligned.
the rear wheels barely fit as it is now, when the fenders are massaged and rolled they should fit close. im looking for small used tires.
notice the differant driveway... we moved. it sucked a lot of time, and some stuffs gonna get alittle lost. the house has a 2 car garage, but until we get another 2 car built, we have a bunch o stuff packed in the garage.
still looking for an intake and bolts.
the turbo coupe wheels are in my "forsale" pile of stuff, have center caps, lugs, and amazing tires.
Old Jan 22, 2007 | 12:24 PM
AMEmilie's Avatar
Hey Andy,
Brick says hi. He's been telling us about his trip to McDonald...says he now knows where they get the ideas for sets for movies like, Texas Chainsaw Massacre.
Glad you're happy with the rims
GerRrg281
44
Nov 18, 2007 08:26 AM
94IVGT
Nov 18, 2006 06:21 PM
97stanger
22
Nov 4, 2006 01:18 PM
roushrider81
Sep 14, 2006 04:55 PM
roushrider81
Sep 14, 2006 03:46 PM
