rear pinion seal
Old Jan 17, 2007 | 05:27 AM
cobra1923's Avatar
Default rear pinion seal
My rear diff is leaking at the input shaft, I'm guessing pinion seal. Is this a job I can do in my garage with average set of tools? I'm thinking drop driveshaft, pull out seal, pound in new seal, put back driveshaft, replace any lost gear lube and FM? Sound about right?
Old Jan 17, 2007 | 08:15 AM
You will need to check the gear engagement when you're done... so you should know how to set up gears and have the dial micrometer. You'll need air tools as well to get the pinion nut off/on. Take it to a shop.
Old Jan 17, 2007 | 08:21 AM
+1 I had the same issue except my crush sleeve wasnt fully crushed took it to a shop gave it some muscle and torqueing and it was ready to go.
Old Jan 18, 2007 | 05:23 AM
cobra1923's Avatar
Thanks guys.....damn it.
Soberdrunk74
May 31, 2012 07:21 AM
sand1303
Mar 2, 2010 07:48 PM
dashiznit74
Jun 3, 2007 09:53 AM
markm
Oct 31, 2006 04:34 PM
gyjunior50
Aug 10, 2006 06:44 AM
