Urgent Help!!!! Shifter Issues!
Old Jan 4, 2007 | 09:05 PM
Rob13288's Avatar
Default Urgent Help!!!! Shifter Issues!
i got a steeda tri-ax shifter for my 2003 mustang gt. 1st 2nd and 3rd work perfectly but when i shift into 4th and 5th the car makes like a low grinding noise??? can anyone help?? (im shifting at 2500-3000 rpms) per gear!! help!!! asap
Old Jan 4, 2007 | 09:11 PM
Check the stop bolts you adjusted while installing it.
Old Jan 4, 2007 | 09:15 PM
Rob13288's Avatar
i did over and over i adjusted about 10 times what is the cause of it??
Old Jan 4, 2007 | 09:26 PM
Youll notice more noise with the short shifter compared to the stock shifter. But this is a noise youll hear all the time. Are you sure its actually grinding? If the bump stops arent in the way, then I cant think of anything else it would be.
Old Jan 4, 2007 | 10:30 PM
Rob13288's Avatar
its like a low low low grind i tightened up everything really tight also another thing the ball on the bottom of the shifter the black thing is suppose to click onto it correct? and not just sit in the little hole the ball goes in. also the stuff thats in the little hole is tran fluid correct? how much is suppose to be in there because its like 1/4 filled when i stuck my finger in it to see how much there was? im wondering if its the little black thing rattling in the hole?
Old Jan 4, 2007 | 10:52 PM
Everything sounds normal to me. Like I said, youll get some extra noise with aftermarket shifters. Youll be able to FEEL the grinding if it was actually grinding.
Old Jan 4, 2007 | 11:15 PM
Rob13288's Avatar
but i reinstalled my old shifter back in and it is doing these sounds also that it has never before. when i pulled the original shifter out it was stuck with the adhsive so i had to jerk it around. u think ic ould have bent something that connects to the gears??
Old Jan 4, 2007 | 11:18 PM
Hmmm, where are you located?
Old Jan 4, 2007 | 11:19 PM
Rob13288's Avatar
peabody, massachuesetts
Old Jan 4, 2007 | 11:22 PM
Ive done a few shifter installs, and had to jerk it around like you did. Thats how the majority remove the stock stuff.
Old Jan 4, 2007 | 11:24 PM
Rob13288's Avatar
this is exactly what it sounds like u know how if when ur goin to shift u put the clutch in but let off before u go and put it into the next gear and it makes a loud KKKKEEEEEKKKKKKKKKKK sound. it sound like that but quieter and only in 4th and 5th gears
Old Jan 4, 2007 | 11:27 PM
My car is auto. When it makes the sound, is the shifter kicking at all? When you grind a gear, the shifter will kick, keeping you from going into gear.
Old Jan 4, 2007 | 11:30 PM
Rob13288's Avatar
if i hold the shifter i can feel the grinding and also hear it but the shifter isnt bouncing around. should i just bring to the ford dealership to have it checked out
Old Jan 4, 2007 | 11:33 PM
Id go to a local Mustang shop.
Rob13288's Avatar
there isnt any around here. im goin to bed maybe it will be magically fixed in the morning. thanks for tryin to help me out. im sure ill betalking to you soon
Old Jan 4, 2007 | 11:39 PM
Alright man, me too. Good luck.
Old Jan 5, 2007 | 05:46 AM
Bwhipple's Avatar
In hibernation
I have a feeling that it might be just normal transmission noise. I noticed more noise also until I took the Tri-ax back out on put in the shifter base gasket. I'd imagine you might still hear the noise when you put the old one back on because the old sealing junk isn't resealing. Just my thoughts.
Here's the gasket by the way.
http://americanmuscle.com/shbahaga.html
Old Jan 5, 2007 | 07:59 AM
mcmmotorsports's Avatar
Resident Mental Patient
If you are hearing a noise when you are driving around in 4th or 5th gear with an aftermarket shifter, it is normal. If you hear a noise when you SHIFT into 4th or 5th gear with an aftermarket shifter you have a problem. Mine makes so much noise in 5th at low speeds that I think my tranny is gonna blow. This has been that way since around 5,000 miles on my '04 GT when I installed my Hurst shifter. The gaskets linked above HELP but don't eliminate the noise.
Old Jan 5, 2007 | 08:33 AM
Rule of thumb when it comes to performance: If it doesn't make noise, it isn't alive. Don't worry it is normal noise that was muffled from the stock shifter.
Old Jan 5, 2007 | 09:11 AM
I think your right about it just being normal noise. It looks like the AM gaskets are out of stock, but I would suggest getting a Cobra Bob gasket instead. I've had both. http://www.stangshiftergaskets.com/
Old Jan 5, 2007 | 08:48 PM
Rob13288's Avatar
the thing is that i put my old shifter back on again and it is making those noises also? when i was removing the stock shifter in the 1st place the steeda installation guide told me it was gonna be hard to remove (which was ) so they told me to put the shifter handle back on and push it to one side and lean until it starts to peel. when doing that could i have pulled something out of place or are the trannys pretty solid that stuff cant get pulled out?
Old Jan 5, 2007 | 08:55 PM
It would sound to me that you logically have a problem. Thing is, noise identification on the internet is VERY tough. You should take that car to a tranny person and have it checked out in case more damaged should take place.
Old Jan 6, 2007 | 03:46 AM
Did you use the same amount of Gasket sealant when you put the old shifter back on?
Old Jan 6, 2007 | 10:13 AM
Rob13288's Avatar
i put enough back on so it was l ike when i put the new one on, i cleaned it up again before i put it back on.
White99V6
25
Jun 4, 2009 10:41 PM
Uneed2Douche
Feb 9, 2008 04:44 PM
Rob13288
Aug 2, 2007 12:37 AM
04redgt
Jun 16, 2006 10:25 AM
