oil filter
Old Jan 3, 2007 | 11:04 AM
dookie2365's Avatar
has no legs
Default oil filter
a pretty noob question, but i never changed my oil before becasue im lazy but im going to start doing it, just need to know if i need a certain oil filter. i know they have numbers on them and my car didnt have an owners manual when i bought it. also how many quarts of oil does the car take in per change? thanks
Old Jan 3, 2007 | 11:37 AM
red281gt's Avatar
just get a mobile 1 filter thats what i use. and mobile 1 synth. oil 5w20
Old Jan 3, 2007 | 12:24 PM
03DSG's Avatar
to better answer the question. your 4.6L enigine takes 6 quarts of 5w20 oil. the oil grade is right on the oil filler cap if you ever forget. now you can go convential, syn blend or full synthetic, its your choice. as for a filter, some filter #'s are fram: PH2 , motorcraft : FL-820S, I cant remeber the mobile 1 filter number off hand, but only get that filter if you plan on using full synthetic and want to go 7000+ mile between oil changes. if you are going to be part of the 3000-5000 mile club fram or motorcraft will do fine.
Old Jan 3, 2007 | 12:57 PM
^^ ditto... cept I hate fram filters. WIX or Warner are good as well. Make sure you lube the filter gasket with a little CLEAN oil prior to installing it and make sure the old filter comes off with its gasket or you could develop a sudden severe leak.
Old Jan 3, 2007 | 01:16 PM
dookie2365's Avatar
has no legs
thanks guys, new i could count on the boards
im gona try n go with the mobil 1 filter n mobil 1 synth, hopefully i get the right 1
Old Jan 3, 2007 | 01:34 PM
If you're rich, K&N. Otherwise, the standard Motorcraft filter is more than enough.
Old Jan 3, 2007 | 01:38 PM
Samsstang's Avatar
Ill have to look at my manual when i get home, but i could of swore that our cars 99-04 only take 5 quarts???
Old Jan 3, 2007 | 02:20 PM
03DSG's Avatar
k&n oil filters only have a 90% eff. rate, thats lower than a standard fram which has a 94% eff. rate, its right on the boxes and also a tough guard fram is 99% eff. and half the price of k&n. a k&n oil filter is for high flow(racing and such) applications not everday driving which is known as severe condition driving. I only know this because i was sent on a day long training session about the different types of oil and oil filters for my job.
Old Jan 3, 2007 | 02:21 PM
03DSG's Avatar
I've been doing my own oil for sometime now, and i;ve always put in 6. I believe at one time the pre- PI 4.6 took 5, but im not sure about that.
Old Jan 3, 2007 | 02:24 PM
03DSG's Avatar
just go to your local parts store, they can look it up for you, i use it my car with royal purple oil, i think is an M1-210, but im not sure, i always have to double check.
**edit**...i just found it, the number for a mobil 1 filter is M1-210 as i had stated.
Old Jan 3, 2007 | 02:29 PM
Samsstang's Avatar
Wow!!! Iam definetly gonna go home and pull the manual, cause i had the opposite impression! i thought pre-PI took the 6 quarts?
Old Jan 3, 2007 | 03:23 PM
never had any 4.6 stang take less than 5.5. I always use almost the full 6 (8 on my car... oil cooler) to get it to the full line.
Old Jan 3, 2007 | 05:40 PM
blackstallion's Avatar
i have been using royal purple 5w-20 and a K&N filter and my 02 gt takes 6.5 quarts.... my manual says like 5 something i think but it is way more then that... I absoutly love Royal Purple if you're interested there is a local shop (MN) that has an online store that sells royal purple 5w-20 fo ra little over 5 dollars a quart (about the same as mobil 1)
www.hitechmotorsport.com (then go to their online store)
Old Jan 3, 2007 | 08:41 PM
My manual for my '03 says 6 quarts. Usually I do 6.5 to get it to the full mark.
Old Jan 3, 2007 | 11:54 PM
dookie2365's Avatar
has no legs
yea i used the full 6 quarts of the mobil 1 full synthetic and was enough...think it could use a lil more but it still hits teh mark
Old Jan 4, 2007 | 07:04 AM
Samsstang's Avatar
Well i own a 99GT & 01 Roush and the manual says 5 quarts for both I even checked my fluid on my 01Roush last nite, havent moved it in 3 weeks and the mark was just barely below the full mark ?? The only thing i found different was the grade of oil changed in some cases like eng 5w-30 to 5w-20 and i believe the diff oil was different too 80w-90 to 80w-140?
mransr
Feb 13, 2008 05:12 AM
bossman302
Oct 10, 2007 07:56 AM
Cobra King
24
Aug 22, 2006 10:03 AM
Beer_farts
Apr 15, 2005 02:17 AM
