The Parts Desk Need an OEM Ford Part? You've come to the right place.
List from MD (database is down)
Old Dec 18, 2006 | 07:34 PM
96TangerineBossGT's Avatar
Default List from MD (database is down)
Randy,
Since the database is down over at MD, I wanted to see if I could get an update on my parts list. I am TangerineBossGT over there. The database may be back up tomorrow, but I am posting here just in case. I would like to get that order done tomorrow, as the motor is coming out Thursday. Thanks.
Scott
Old Dec 19, 2006 | 05:01 AM
Randy Stinchcomb's Avatar
Originally Posted by 96TangerineBossGT
Randy,
Scott
sure no problem, glad I got Back-up over here and on Modular Misfits
right now your total is at $112.85 for the parts, - the fuel line stuff and I still had a question on the 10(?) cam cover gaskets
Old Dec 19, 2006 | 05:35 AM
Yeah, I responded over there but since things went down, maybe you didn't get it. I needed 10 of the rubber grommets for the cam cover bolt holes, not 10 of the cam cover gaskets. I ordered 2 a while back from you but it turns out that now I have more leaking. If I get 10 of them now, I will have new grommets in all of the lower holes, where the oil is likely to settle and leak from anyway.
I just needed a pair of the cam cover gaskets. I wanted the red cover gaskets, the ones with the provisions for connecting around the grommets and in the groove, while the grey ones simply fit into the groove. I looked back through my records and they are different part numbers. I posted that over at MD as well. I can look it back up if there is still confusion there. I ordered 2 a while back from you but it turns out that now I have more leaking. If I get 10 of them now, I will have new grommets in all of the lower holes, where the oil is likely to settle and leak from anyway.
The fuel line is not as big a deal, just thought I would replace it with everything out. I didn't actually punch a hole in it so it leaks, but enough to where I felt the need to tape it up to prevent further damage. I don't want that to hold up everything else, since I don't HAVE to have it. You said it was discontinued, so I can figure something else out if it becomes a problem.
Scott
Old Dec 19, 2006 | 05:37 AM
I know last time you only had like 2 grommets in stock, so if they must be ordered, then we can just do them separately so that everything else can hopefully get here this week.
Scott
Old Dec 19, 2006 | 06:41 AM
ok, gotcha'
just ordered the 10 grommets and the radio filter/supperesor new total is $139.25 + shipping and your ref # is 154440
Old Dec 19, 2006 | 06:49 AM
ok, gotcha'
ok, should I get everything this week, since the grommets and the radio filter have to be ordered or are you gonna ship the other stuff now and those two later? Just didn't know how long it would take you to get those in.
Open your PM box and I will send you my info.
Thanks
Scott
Old Dec 19, 2006 | 07:33 AM
Thanks
Scott
PM box is opened, I think I can have it all ready to-go by tomorrow and NC is 2 days wth regular UPS grouns, so we should be ok.
Old Dec 19, 2006 | 07:35 AM
PM sent..
Old Dec 19, 2006 | 07:57 AM
PM sent..
ok, got-it.
MattJ
85
Feb 8, 2010 04:20 PM
PColav6
SMACK Talk!
Jun 25, 2008 07:40 AM
FikseGTS
Dyno Results
Jun 25, 2006 01:27 PM
StangGT804
Aug 10, 2005 09:01 PM
fallstar
Jul 26, 2005 12:12 PM
