arg!!!!! damn exhaust/clutch
Old Dec 5, 2006 | 04:32 PM
Angry arg!!!!! damn exhaust/clutch
im officially fed up w/ my exhaust. i had the header studs replaced with the supplied studs from SLP. exhaust doesnt leak and it sounds awesome with out the tapping noise. but now, part of the clutch mechinism is grinding against the pipe. also, the enguage point is much lower to the floor (not really complaining about that) and it is a real effort to use the clutch now. i know i pulled something in my quad driving 5 mins home
any help would be great. also, im not gonna get a quadrant/firewall adjuster because it wasnt like the way it was now before i took it in. and this is a guy that has been working on my car since day one so i can trust him that he didnt do anything wrong on purpose
Old Dec 5, 2006 | 05:54 PM
this is why i don't let anyone work on my car...
he ****ed something up
heres my suggestion...
(i'm assuming you bought longtubes, right?)
Get a thicker header gasket (like a nice copper one)
That will move the headers out a little and should give clearence...
BUT those headers are made for your car so theres still no reason for the any clutch hardware to hit it...
IDK... I'd have to look at it, find the problem and fix it...
Old Dec 5, 2006 | 06:02 PM
nope no headers. only replaced the stock header studs taht go to the mid pipe cause there was not a good seal causing an exhaust leak. he wrote me a not sayin that the pipe prior to the cat was not lined up good
the only thing is i dont know y its doing it now. all he should have done is unclamp the pipe, take out the studs and replace, and clamp the pipe back on. it is probabl a half inch moved from where it was w/ the leak.
Old Dec 5, 2006 | 06:13 PM
try adjusting the clutch cable. My honda felt like it had a freakin racing clutch in it when i got it. Same thing too, the clutch diddnt release untill the pedal was damn near the floor.
i tightened the clutch cable and the release point came father out and the pedal was far far easier to push in.
or do the mustangs have hydolic clutches?... eh.
no..mustangs have cable clutches. im not gonna touch it until he looks at it again. it didnt do this when i took it to him so it has nothing to do about reajusting the clutch..besides i dont think that what ever is part of the cluch is supposed to be hitting the exhaust
Old Dec 5, 2006 | 06:21 PM
dont be skerred to adjust it. it is easy, and it is hard to mess it up.
his working might have possibly damaged the clutch cable, it might have slipped a bit and loosened up
im not concerned about how low the enguage point is. im concerned about the hitting my mid pipe point and how hard the cluthc is to push in. my mom cant push it one bit and she drives manual too
Old Dec 5, 2006 | 06:42 PM
ok..im gonna try what you said..now how exactly do i go about adjusting it?
Old Dec 5, 2006 | 06:47 PM
96gtstang's Avatar
i was under the impression or i was pretty sure i guess that after the fox bodies? or somthin like that all mustangs had hydrolic clutches- non hydrolic clutches need adjusting "often" what jack said is true about it being loose but in reality once a hydrolic clutch is installed it shouldnt need adjusting ever.
Old Dec 5, 2006 | 07:04 PM
not what it says here:
http://www.corral.net/tech/drivetrain/clutcha.htm
i still cannnot figure it out even w/ reading this many times
The 64-04 mustangs have cable clutches in them.
All you do is put the car in first gear with the motor off lift the clutch pedal with your foot till it goes up a hair or so, then press it down slowly all the way to the floor this will adjust the cable. You may need to do this a few times till its right.
Old Dec 5, 2006 | 07:06 PM
lol... wow...
Old Dec 5, 2006 | 07:07 PM
Originally Posted by GREG@SN95
lol... wow...
what its amazing they had them for 40 years?
Old Dec 5, 2006 | 07:08 PM
i wish i had my haynes manual with me, but it is the mustang which is parked in the garage and im at work.
thank you!!!! i forgot i had the manual.lol
Old Dec 5, 2006 | 07:12 PM
WOW no ****? just bit lifting it up and lowering it? Damn. wish my honda was that easy!!!!!!!!!!!!!!!!! Instead i had to yank out the battery with its god-awful battery anchoring thing in order to get to it.
Yeah its a cool little design. i tend to do mine every 2 oil changes or so and it stays right around the middle for engagement.
Old Dec 5, 2006 | 07:13 PM
that someone needed to say that... lol...
Old Dec 5, 2006 | 07:18 PM
its not going away at all. not one bit better and i did it at least 15-20 times
Old Dec 5, 2006 | 07:26 PM
Originally Posted by wnracing
I absolutely hate the stock "auto adjusting" quadrent gear. Never worked worth a **** for me. Ill stick to my Steeda Quadrent, and firewall adjuster! lol Much smoother, and nice to have easy adjustability.
works fine for me... yer all just a bunch of degenerate **** ups
lol
Old Dec 5, 2006 | 07:51 PM
well im assuming that the cable attaches to a lever near the bellhousing. hopefully the mechanic diddnt bend or damage the lever.
if you have somebody with you, get under the car and have them engage and release the clutch, try to find the lever on the tranny that the cable connects to. the lever should be TIGHT, there shouldnt be ANY play on it....
well..looks like this will have to be handled by the mechanic or ill fvck with it on the weekend..i hope nothing is bent. the tranny/clutch isnt what i wanna focus on right now
Old Dec 5, 2006 | 07:59 PM
vid: http://youtube.com/watch?v=H0-IGIHm1gA
you can hear the grinding right before the sqeeking, also, on the last bit, i hold the clutch all the way in and keeps sqeeking for 1 or 2 secs
Old Dec 5, 2006 | 08:21 PM
How loose is the pedal? Is there a 1/4" play before it engages (the point where you feel the clutch enaging and start getting stiff)? If so, your cable is loose. If not, a possibility is that the cable is too close to the exhaust manifolds/H-pipe causing the cable to melt.
Also, 79-04 Mustangs had cable, 05+ uses hydraulic, and 64-78 uses mechanical linkeage (z-bar that consists of 2 metal rods).
Old Dec 7, 2006 | 02:52 PM
i got it fixed. there was a sheild that protects the clutch cable and some fork that was being rubbed each time i pushed the clutch
