Clutch compatibility
Old Nov 29, 2006 | 11:54 AM
gt_stang99's Avatar
Default Clutch compatibility
Hi,
I have a 99 GT and the transmission bearing is going out so I'm getting it replaced, while I'm getting it replaced I'm putting a new clutch in it. It has a stock clutch in it right now but I'm going to put a stage 1 in it. I was thinking about the SPEC stage 1, is that compatible with the stock transmission? Also, does anyone know of a better stage 1 clutch that can be installed to a stock transmission?
Thanks
Old Nov 29, 2006 | 02:32 PM
yes...any clutch is compatible w/ the stock transmission..its just the type of clutch to your power you need to worry about..if ur spending the money, go with the Stage II cutch. no-one i have talked to was satisfied and went to a stage II and loved it..
also...make sure it fits the T-45 tranny that the 99's came with
http://www.americanmuscle.com/spec-s...45-clutch.html
Old Nov 29, 2006 | 03:54 PM
gt_stang99's Avatar
Would you suggest the Stage 2 SPEC or a King Cobra? I've been looking at previous posts and a lot of good things about the King Cobra and a lot of bad things about the SPEC's...
Old Nov 29, 2006 | 04:04 PM
both are good it depends on your future mods if your gonna go to a spec 2 or a king cobra really.
Old Nov 29, 2006 | 05:36 PM
gt_stang99's Avatar
So http://www.americanmuscle.com/spec-s...45-clutch.html comes with everything needed to install, right?
Thanks for help btw.
Old Nov 29, 2006 | 08:40 PM
yep, but do yourself a favor and get a ford throw out bearing and pilot bearing as the specs tend to go bad fast.
Old Nov 29, 2006 | 09:41 PM
unless you have a few mods and are making extra power... the stock clutch is fine... cheaper to get 1 from napa then pay extra for something ya don't need
Old Nov 30, 2006 | 12:50 PM
gt_stang99's Avatar
I plan to add mods to it soon, so want to go ahead and get a clutch that can handle it.
Also, http://www.jegs.com/webapp/wcs/store...10002_89536_-1 and http://www.jegs.com/webapp/wcs/store...0002_123541_-1 for the bearings? Would those work with the SPEC 2?
Old Nov 30, 2006 | 05:07 PM
stock clutch can handle anything til you get to being supercharged, turbod, or a bad NA setup...
unless you want to race it...
So for bolt ons I wouldn't bother with an expensive clutch
Old Nov 30, 2006 | 06:00 PM
gt_stang99's Avatar
Yeah, a Kenne Bell is definentaly coming Don't want to have to spend that extra money to put a stage II in in order to get a KB when I can go ahead and get one put in while the transmission is out for the bearing. Btw, are those the pilot and throwout bearings I'd need in the above post?
Thanks
Old Nov 30, 2006 | 06:13 PM
Thanks
yup
Kyanbi
35
Aug 14, 2009 06:38 PM
sto73
Apr 15, 2007 02:32 PM
gt_stang99
Nov 29, 2006 11:22 AM
r3dn3ck
Jun 6, 2006 11:29 AM
AlCapwned
Jul 9, 2005 01:47 AM
