Defrost Stuck
Old Nov 20, 2006 | 02:05 PM
contrail1's Avatar
Default Defrost Stuck
My Heating and A/C is stuck on defrost. The blower works fine and the A/C works fine but the air isn't coming through the vents. What could be the problem and will it be an expensive repair. Help...
Old Nov 20, 2006 | 06:17 PM
my car did the same... never figured out what the problem was...
I think it was the heater switch unit itself... never got a chance to replace it before the wreck...
I checked all the wires, connections and fuses and they were all ok...
so check that and if it yeilds no results then get new ****/switches
Old Nov 21, 2006 | 06:02 PM
contrail1's Avatar
Default Thanks
Thanks for the response, I check the fuses and wiring and vacuum tubes; all were in good shape. I was thinking of replacing the switch but it seems it works because it still turns on the A/C.
Old Nov 21, 2006 | 06:21 PM
idk...
mine was wierd as hell
the fans worked 50% of the time... sometimes they would get stuck on a slow speed or not come on at all...
also... the fans would only blow out the dash... no matter what setting...
So
sometimes I could control the speed
but if that particular day it decided to work it'd blow out the dash
I think you have the same problem... I bet its the switch... I took my entire dash out and checked wires... had to be the switch inside..
Old Nov 22, 2006 | 11:37 AM
contrail1's Avatar
I'm going to try replacing the switch, we'll see how it goes.
B-rett
May 18, 2009 10:24 AM
cune7705
Jan 16, 2008 08:55 PM
Xilan
23
Feb 23, 2006 10:38 PM
venom
Sep 27, 2005 08:06 AM
JDawg965
Jul 30, 2005 11:55 AM
