Braking Noise
Old Nov 18, 2006 | 02:24 PM
stage2roush2002's Avatar
Roush #6147
Default Braking Noise
A strange noise is coming from the front of my car when I brake. The pedal also vibrates a little bit. The sounds is kinda a grinding squeking noise, but not really high pitched. Any ideas? Please help!
Old Nov 18, 2006 | 02:32 PM
4.6 Love's Avatar
Is it coming from the calipers?
Old Nov 18, 2006 | 02:35 PM
when was the last time you had your brakes serviced?
Old Nov 18, 2006 | 03:44 PM
Chasinsparks's Avatar
Time to get the MIDAS touch. It sound to me you need a Brake job
Old Nov 18, 2006 | 03:47 PM
4.6 Love's Avatar
I hope you are kidding about MIDAS! They are a bunch of ****ing thieves! I'd do my own brake job before going to those ********!!
Old Nov 18, 2006 | 04:02 PM
Ghostalker's Avatar
BOLO 4 ME
always do your own work on your car unless it is beyond your mechanical capability...
Old Nov 18, 2006 | 06:09 PM
check your pads for uneven wear and check the back side of the rotors for gouging/scratching. the pulsing is usually a sign of a slightly warped rotor.
If you can afford them, 1 piece Baer Eradispeed plain faced are almost warp proof. I use em and I have tried in vain to warp them so I can get some 2 piece eradispeeds so they're definitely pretty tough.
Old Nov 18, 2006 | 06:23 PM
Was joking about midas, if you pay for a break job you are thowing money away
Old Nov 20, 2006 | 09:01 PM
Roush #6147
I have never had a brake job. The car just hit 11,000 miles. Its only coming from the front left brake too.
Are brakes easy to do?
Old Nov 21, 2006 | 03:42 PM
such simple cake it's a wonder midas stays in business. Check to make sure the lugs are tight on that wheel before you do anything to fix the brakes.. that's sometimes an issue especially with aluminum wheels.
if it's just that side then get the rotor checked for warpage and replace as needed.
I do all 4 wheels on my car with new pads and rotors in about an hour. Less is the rotors don't have to come off for turning. Remember...you don't have to pull the caliper mounting bracket... just the floating caliper. Takes about 5 minutes a side plus jacking and wheel mount/dismount time.
probiker427
Jul 3, 2010 07:45 PM
mustngspd
Feb 20, 2009 02:18 PM
Kidstang
Sep 24, 2006 09:12 PM
BraggStang
Drag Racing!
May 29, 2006 05:55 PM
SIU-EIT
Sep 19, 2005 12:39 PM
