Trouble Code
Old Nov 14, 2006 | 01:13 PM
ShapeShifter's Avatar
Default Trouble Code
hey guys this past Friday my check engine light came on and i plugged in my SCT to see what comes up,i got the trouble code P1151
http://www.obd-codes.com/trouble_codes/ford/p1151.php
so i already cleared it,but my question is should i worry about this,my car seems to be running normal...?
Old Nov 14, 2006 | 01:21 PM
Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
You might need a new O2 sensor
Old Nov 14, 2006 | 06:24 PM
which one, a rear o2 sensor?
Old Nov 15, 2006 | 08:12 AM
99% sure it's driverside and if it's upstream which it is I'm pretty sure its the one before the cat
Old Nov 15, 2006 | 08:37 AM
you must have an aftermarket mid pipe.
Old Nov 15, 2006 | 08:45 AM
He has a O/R pipe.
Old Nov 15, 2006 | 08:48 AM
Originally Posted by Icefreezen
He has a O/R pipe.
Gotcha. If you have been thinking of getting an Xcal or any tuner, you can also turn them off using that. Just an added incentive to get one
Old Nov 15, 2006 | 08:56 AM
Thats whats strange though.....on the O/R pipe you need MIL eliminators or you need to shut them off with a tuner. The O2 sensor thats throwing the code is the one that NEEDS to be there the fronts.
Old Nov 15, 2006 | 09:05 AM
Hmmm... Well I have catted SLP Xpipe and I threw both bank 1 and 2 codes because of flow. It basically was throwing this because the 2 pre-limenary cats were eliminated due to the SLP Xpipe. We by-passed this w/ the tuner. I don't have MIL eliminators, since I have catted pipe, correct? My 02 sensor's were just picking up the extra carbon or whatever it is to throw the a/f off.
Old Nov 15, 2006 | 09:13 AM
I have a catted pipe too but had mine shut off in the rear just for the fact I wont have to pay for them when they crap out . But thats not the point.
There is a upstream and downstream trouble code and the one he is throwing is the one in the front. The codes you threw are probably both the downstream which is past the cats he is throwing the one beofore the cat or the one in the front.
Old Nov 15, 2006 | 09:18 AM
You would still be able to turn that off with a tuner however.
BUT, I don't know what to tell him since he doesn't have one. I don't know what to do then.
WHY IN GODS NAME WOULD YOU TURN OFF THE FRONT!!!
Old Nov 15, 2006 | 09:19 AM
If it's throwing a code?
Old Nov 15, 2006 | 09:24 AM
You'll be causing more harm than good
Old Nov 15, 2006 | 10:15 AM
hmm k,i have an O/R Pipe,i have my rear o2 sensors shut off of course,so i have to repair the one prior to the cat(ie front passenger o2 sensor)...? how much will that run me?
Old Nov 15, 2006 | 10:27 AM
Bank 2 should be drivers side....and a 02 sensor should run for $40-50. I recommend you change both out while your under there
Old Nov 15, 2006 | 10:29 AM
hmm not too bad...and how does this usually happen,how do these o2 sensors go out...? ohh and where would be the best place to buy one?
Old Nov 15, 2006 | 10:36 AM
I dont know where the cheapest place but any local autoparts store should have them. They go out usually due to carbon build up and can go out after time.
The reason why you should change it before it fails is when the oxygen sensor fails, the computer can no longer sense the air/fuel ratio, so it ends up guessing. Your car performs poorly and uses more fuel than it needs to.
Old Nov 15, 2006 | 10:46 AM
Old Nov 15, 2006 | 10:49 AM
It will be fine but i'd take a run down to your auto parts store and see what they have because your going to be paying more with that shipping charge. It may be $49.95 at your store and that saves you $10
Old Nov 15, 2006 | 10:50 AM
true,thanks for all your help man!!
Old Nov 16, 2006 | 09:27 PM
would it be ok if i used one of my rear o2 sensors and put it in place of my fugged up front o2 sensor,being that the rear o2 sensors are disabled..?
Old Nov 16, 2006 | 09:49 PM
I'm pretty sure it will work but i'm not sure if the connections will reach. But it's worth a shot
Im surprised Randy hasnt came in here yet. Do not replace your 02's with anything besides Ford parts. Get new 02's from him.
Old Nov 16, 2006 | 09:51 PM
Really i've had people use aftermarket O2 sensors and they work fine. WHy is that?
Old Nov 16, 2006 | 09:57 PM
Not sure why, never asked. I guess they just arent good quality. But Randy knows his ****, so I listen.
Old Nov 16, 2006 | 10:05 PM
RANDY!!!!!!!!!!!!!! GET IN HERE!!!! He's probably out fishing
Old Nov 16, 2006 | 10:11 PM
hmm i might give it a shot either way..thanks gents!!
tluckie13
Jan 10, 2010 07:07 PM
v6'stang
Dec 11, 2009 07:23 AM
stage2roush2002
Jul 15, 2007 07:39 PM
stage2roush2002
Jun 15, 2007 09:43 AM
Bassani
Jan 22, 2005 08:29 PM
