Xcal 2 Dtc
Old Nov 11, 2006 | 02:15 PM
98-GT's Avatar
Default Xcal 2 Dtc
The check engine light came up on my 98gt and it threw two codes- p1131 and p1260, where would i go to find out what these mean.
Old Nov 11, 2006 | 02:31 PM
Autozone.
Old Nov 11, 2006 | 02:32 PM
Old Nov 11, 2006 | 02:42 PM
98-GT's Avatar
ok thanks alot
Old Dec 7, 2006 | 06:20 PM
98-GT's Avatar
I clear the codes, and a few days later the same code came up again(Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1) but from another o2 sensor. The car seems to run fine does this mean i need new o2 sensors, or a whole new tune since it says im running lean?
Old Dec 7, 2006 | 06:31 PM
well. if u wanna check if u are really running lean then you should put it on a dyno and check the A/F ratio. do you have an aftermarket midpipe? if u do that could be causeing the SES light
Old Dec 7, 2006 | 06:59 PM
Whats done to the car?
Old Dec 7, 2006 | 07:22 PM
98-GT's Avatar
I bought the car used with a catback and I think it has hi flow mid pipes because it only has 2 converters. Other then that I did a pi swap and have a 160 thermostat. I've been driving the car since the begining of september with the swap.
Old Dec 7, 2006 | 09:21 PM
Full PI swap? Get it tuned.
Old Dec 8, 2006 | 09:09 AM
98-GT's Avatar
i got a tune from mustang tuning when i bought the sct
Old Dec 8, 2006 | 10:46 AM
98-GT's Avatar
when i ordered the tune i had included everthing done to the car even the pi swap. Do you think its still the tune and i should have it dyno tested?
Old Dec 12, 2006 | 07:17 AM
red281gt's Avatar
still get it dyno tuned! even if they tuned for the heads its only enough to hold off a dyno tune for a short time. Nothing beats a dyno tune cuz then you can get the A/Fs at the perfect numbers(unlike mail orders which can have the car run lean or rich). oh the other plus for the dyno tune is you can see your numbers then.
Old Dec 12, 2006 | 10:15 AM
98-GT's Avatar
sounds good ill go with that then thanks
32vRacer
Mar 15, 2008 10:06 AM
BrentK
Aug 5, 2006 09:09 AM
2K05GT
25
May 8, 2006 06:02 PM
kirsch
Nov 28, 2005 12:17 PM
MattJ
21
Aug 21, 2005 10:24 PM
