Plans for nitrous
Old Nov 8, 2006 | 04:58 PM
  #31
Christie how much do you figure you are going to spend by the time you have everything you need including dyno tune?
Old Nov 8, 2006 | 04:59 PM
  #32
The focus pump flows more, which means when the computer demands more fuel it will be able to supply more fuel to the engine and recover faster from the lean spike.
Old Nov 8, 2006 | 05:02 PM
  #33
cuban3jumper's Avatar
Your local V6 Guy
[QUOTE=03gtmustang;221587]
Originally Posted by spike_africa
True and not true, the higher flowing pumps recover faster from the inital hit then stock one. QUOTE]
Exactly.
You plan sounds good.
Ok so could someone explain to me why now. I don't see how a better flowing pump can react quicker when the action of reacting comes from the computer.
Old Nov 8, 2006 | 05:04 PM
  #34
[QUOTE=cuban3jumper;221590]
I have no idea, but your car looks awesome - LOL
Old Nov 8, 2006 | 05:05 PM
  #35
Your local V6 Guy
[QUOTE=WaterDR;221591]
LOL thanks I appreciate it
Old Nov 8, 2006 | 05:07 PM
  #36
csledd's Avatar
DSG!!!
Under $1300 minus gauges, gonna try to do a little better. That's the most for whats necessary. (Nozzle kit, GenX-2, spark plugs, msd window switch, MT switch, focus fuel pump, dyno tune)
Old Nov 8, 2006 | 05:14 PM
  #37
Its not the reaction, its the amount of fuel flowing. The focus pump can flow more fuel thus recovering from the lean spike faster.
Old Nov 8, 2006 | 05:57 PM
  #38
JayC's Avatar
Cage Fighter
Originally Posted by csledd
well I plan to go with the nozzle system now, getting the svt focus fuel pump, and a dyno tune. sound good?
After reading these posts, how have you decided you want a Nozzle system....I'm confused
Old Nov 8, 2006 | 07:30 PM
  #39
csledd's Avatar
DSG!!!
well, from what people are saying, the plate kit has a nasty lean spike, but also i know a good deal on the nozzle kit lol. what are the cons of the nozzle vs the plate? i figured either would be fine.
Old Nov 8, 2006 | 07:48 PM
  #40
Not to be a ****-bird...$1300 (which is great for all that stuff) but when you add your guages (nitrous guages are expensive too) you could easily add another $300 - $500 for them plus dyno tune. Any thoughts of a blower?
(OK, I will now go back to my corner)
Old Nov 8, 2006 | 07:54 PM
  #41
You do bring up a good point...something you can do is get what you need to get the system to work....tune it eliminate the guages for now to what you need right away and then progressively build from there
I have the nitty gritty but the tune is the most important thing I could have
Old Nov 8, 2006 | 07:56 PM
  #42
csledd's Avatar
DSG!!!
I was waiting for you to make this suggestion lol..
just remember, I have N/A cams.. a blower is out of the question! Plus, I want to still able to make N/A runs. The $1300 includes the dyno tune.. so you could say I'm still under $1800 for everything. That's almost $2000 away from a mongoose kit, plus I would need a cam swap to make the blower truely effective. Nitrous is the better route for what I want to do with this motor, for now.
When I did the cams I never planned to put boost on this motor, which is why I went the N/A route.. and I knew I would still have the option to spray, and the VT N/A cams looooove spray.
Old Nov 8, 2006 | 07:57 PM
  #43
csledd's Avatar
DSG!!!
I'm a woman.. I like to accessorize, lol.
Old Nov 8, 2006 | 08:20 PM
  #44
Yes you do. I think you know my future plans which Ill keep secret for now...
Old Nov 8, 2006 | 08:31 PM
  #45
Your local V6 Guy
That makes no sence that would be more in the tune or the computers programming. I understand that a better fuel pump is well better but this is a mechanical limitation of a returnless system. That comes directly from tuners like Justin at VMP, my tuner and a few others I have heard have this discussion. The NX accumilater though seems to be a solution to the lean spike on a returnless car, check it out if you haven't. Kind of expensive as far as nitrous accesories go but if you're that concerned about the lean spike it's your answer.
Old Nov 8, 2006 | 08:39 PM
  #46
(I am still in my corner)
Old Nov 8, 2006 | 08:42 PM
  #47
csledd's Avatar
DSG!!!
Old Nov 8, 2006 | 08:47 PM
  #48
Well Im not having any lean spike issues with my focus pump and foot longer nitrous line.
Old Nov 8, 2006 | 08:57 PM
  #49
Your local V6 Guy
And niether am I with a stock fuel pump. Of course the fact that you guys are making more power then me would warrant a fuel pump swap all I'm saying is from what I've seen and heard from others and myself in fact with similar cars and mods the addition of a better fuel pump does not necessarily negate the lean spike issue.
Ok anyways your plans sound great how much you planning on spraying? If you know you're not going over 125 go with a mainline kit, NX quality at a $200 less price tag.
Old Nov 8, 2006 | 09:02 PM
  #50
csledd's Avatar
DSG!!!
125 would be the highest I would go, being realistic though.. probably only 100 shot.
Old Nov 8, 2006 | 09:13 PM
  #51
We already talked about this it doesn't matter if your a girl jk..haha
Old Nov 9, 2006 | 05:54 AM
  #52
JayC's Avatar
Cage Fighter
Sorry , I was mistaken. I thought you were refering to the NOS Nozzle kit that is direct port. A standard NX EFI single nossle kit if the way to go
Old Nov 9, 2006 | 06:35 AM
  #53
why is fuel pressure more important than knowing oil pressure? just curious, i thought oil was more important, but im a newbie
as far as I'm concerned... fuel pressure being too low can end you with a destroyed block. low oil pressure can wreck a bearing etc...
basically it's the repair cost of a failure at each point. low fuel pressure causes really expensive catastrophic events like big detonation and subsequent broken pistons and rods. Low oil pressure causes spun bearings and scratched cylinder walls. It's cheaper to replace some bearings than it is to buy a new rotating kit or worse yet... a new block.
Old Nov 9, 2006 | 10:02 AM
  #54
Correct. its not how fast it reacts (as both pumps react with the same amount of time) but its the fact that the focus pump pushes more fuel on the same voltage then the stock GT/v6 pumps do. So when you have more flow it will recover fast beings its flowing more fuel to the enigne and nitrous kit. THats about as detailed as i can get lol.
I still can belive you all have so much $$$ invested in your kits. I am still not over $700 in my kit + odd's and ends. Once i get a used heater and a tune i will be around mid-upper $900's thats it.
Old Nov 9, 2006 | 02:27 PM
  #55
csledd's Avatar
DSG!!!
haha, oh hell no.. im nx all the way
sweet, thanks for the info..
40thblckgt
27
Sep 9, 2007 08:23 PM
New Products
New American Muscle Products
Aug 2, 2006 03:05 PM
New Products
spike_africa
Jul 16, 2006 07:20 AM
BrentK
Jul 27, 2005 01:56 PM
