Blower Issues
Old Nov 8, 2006 | 02:13 PM
Default Blower Issues
I just started up the car today after it had been sitting for a few weeks. When the car is cold, I always get a "blap, blap, blap" sound comming right from the blower itself. Within a few seconds, the sound goes away. I have attributed this to the oil being dry from the blower (but don't know if this si true).
Today, the sound was especially noticeable and went on for a few minutes. I popped the hood, and each time the blower was making the "blap" sound, the belt was actually trying to jump off the blower pulley.
I think something is causing the blower pulley to be hard to turn.
Can someone shed some light on this for me? Is this a "normal" ocurrance with a blower or is something dicked-up?
Old Nov 8, 2006 | 02:28 PM
pull the belt and spin the pulley by hand. if it's no bwaynoh, send it back. it should spin freely. Perhaps a bit of sludge caked inside the v on some of the gear teeth
Old Nov 8, 2006 | 02:40 PM
Old Nov 8, 2006 | 02:43 PM
if the pulley doesn't spin freely, then it's not good (no bueno <-- correctly spelled). Send it back to manufacturer for repair.
Old Nov 8, 2006 | 03:30 PM
****....looks like I need to talk to Paxton. Timing is good as I have all winter to fix - LOL
Old Nov 10, 2006 | 09:22 AM
I know what that is...mine was doing it right after I had put it on the first time. Its your belt alignment. Your blower bracket is crooked on there likely from one or two loose bolts attatched to the timing cover. Try tightening the bolts that hold the bracket to the motor. Definately dont rev it up cause that belt will jump off.
Old Nov 10, 2006 | 02:42 PM
his last post made it sound like his blower pulley doesnt spin by hand. so it has to be rebuilt.
sucks to have that happen. hope my vortech is fine, my mom said she hasnt started the car in a couple months.
Old Nov 11, 2006 | 09:15 AM
Dude....I found a bolt pulled nearly all the way out. When I get a chance, I will tighten it all up and start it up.
Old Nov 11, 2006 | 09:47 AM
if you can pull it out, be sure and dab some threadlock on there so it doesnt come back out.
Old Nov 11, 2006 | 11:55 AM
Dam! Looks liek I need to pull a lot of the intake out of the way to get at the bolts just to tighten them.
I think I am going to get the belt off too, just to see if I can spin the pulley and then just replace it at the same tim.
What I really need is a mechanic....I am all thumbs. I had a great guy I could use in PA, but since I moved to WI, I don't know anyone. I don't want to use a dealer. I wish there was a speed shop in town somewhere.
Old Nov 11, 2006 | 08:05 PM
I wouldnt tackle a head unit removal/install by yourself. I dont know how the paxton brackets are made, but the vortech is a PITA to work on.
Old Nov 11, 2006 | 09:50 PM
the paxton bracket is made to where you can do belt changes without removing the head unit. way easier then the vortech. its a pain to have to remove the whole intake, i have a huge powerpipe that goes all the way down to my bumper in front of the foglight. its a snug fit. after that every bolt is a straight shot i had to buy some pry bars just to get my belt on.
just tighten the bolts and see where you stand, before you do that make sure you can spin the pulley by hand.
PistolWhip
Jun 2, 2005 06:35 PM
MachGT
Apr 22, 2005 10:45 AM
MachGT
Apr 15, 2005 09:00 AM
MachGT
Mar 23, 2005 09:11 PM
Jeremy
Dec 20, 2004 10:54 AM
