Wheel Balancing?
Old Oct 28, 2006 | 06:02 PM
mcmmotorsports's Avatar
Resident Mental Patient
Default Wheel Balancing?
For those with AFTERMARKET wheels only, are you guys (gals) having problems keeping the wheels balanced?
Old Oct 28, 2006 | 06:15 PM
i havent had much trouble.... i got the interior stick-on weights rather than the clip on exterior ones...
how often do you have to balance your tires?
When I bought them used(already mounted), they were vibrating pretty bad. I took them to a local shop and he balanced them. They did fine for a little while but they are vibrating again...maybe a weight fell off.
Old Oct 28, 2006 | 09:41 PM
I sort of have a problem, I'm not real sure if it's with the wheels or tires. The tires are pretty low profile, 245/40/18's. If all the tires are not with in 2 PSI of each other I can feel a little shaking at highway speeds. So I keep all tires at 25PSI.
Old Oct 29, 2006 | 09:37 AM
even pressure has been the biggest improver for me. When they're not the same I can REALLY feel it. Car pulls to one side. When they're balanced pressure the car tracks straight. I've decided that all the extra grip from the Coil over and tq arm has made it extra sensitive and treat it accordingly.
Old Oct 29, 2006 | 02:07 PM
littledonko's Avatar
stick on weights inside with out a problem so far. 17x10.5 bullitts.
Old Oct 29, 2006 | 03:05 PM
Stan's Avatar
Beantown Stang
I go to DirecTire there the best at mounting and balancing they know there **** too, the guy said on aftermarket wheels they always put the weights inside the wheel, which I prefer a hell lot better.. but to answer your question ive had no problems with my wheels..
whitecobra_1995
Jan 22, 2005 11:55 PM
NoKturnaL
Jan 9, 2005 07:05 PM
04 STANG
Dec 21, 2004 05:46 PM
Black01
Nov 25, 2004 07:48 PM
Tunez
Sep 15, 2004 04:01 PM
