how much hp?
Old Oct 26, 2006 | 03:41 PM
gotMACH04's Avatar
Default how much hp?
anybody know, how much hp would an internally stock 4.6 mach motor be able to safely handle?
Old Oct 26, 2006 | 03:42 PM
3V2000GT's Avatar
46MONSTER
i think 480-520rwhp, i think, i know they strong engines
the manuals have a froged crank
Old Oct 27, 2006 | 09:38 AM
bad question... the internals have no exact break point in power. They do have a real sensitivity to bad tunes though, so whatever you're going to do to it have it tuned really well.
I'd stop before 500hp. 460-480 would be quite a lot to ask of it on pump gas.
Old Oct 27, 2006 | 03:02 PM
gotMACH04's Avatar
basically what im wanting to know is will it handle a blower, and how much psi
Old Oct 27, 2006 | 03:13 PM
yes with a really solid tune. I'd keep it to 6-8 non-intercooled or no more than 9 -10 intercooled.
Old Oct 27, 2006 | 03:14 PM
expect a LOT of hp gain and decent tq numbers. the mach motor is high compression and it makes ugly power from a little boost.
Old Oct 27, 2006 | 03:15 PM
gotMACH04's Avatar
correct me if im wrong but i change boost level with different size pulley?
Old Oct 27, 2006 | 03:16 PM
4.6 Love's Avatar
yes...
Old Oct 27, 2006 | 04:19 PM
Here is Scott Hoag's (designer of the Bullitt and Mach 1) response to the same question asked on the mach 1 registry.
"Unfortunatly you are asking a theoretical question. Assuming the
rotating assembly is manufactured to nominal tolerances and the rotating
assembly is perfectly balanced and the calibration is flawless....you could
make tons of power....the final question is: how long will the engine make
this power?.....there in lies the performance paradox....no one can answer
this question, it will be what it will be.....welcome to the thrill and
excitement of building performance!"
Scott Hoag
Old Oct 27, 2006 | 07:51 PM
you will need different tunes with different boost levels. its all in the tune most of the supercharged machs i seen are in the high 400's.
40thblckgt
Jun 10, 2006 12:46 PM
ItSaGiRlStAnG
22
Dec 7, 2004 03:09 PM
23
Oct 31, 2004 06:58 PM
Jeremy
Oct 8, 2004 06:19 PM
Sep 27, 2004 05:39 PM
