Thinking of doing nitrous on my 07 GT, nitrous gurus only!!! HELP!
Old Sep 5, 2007 | 07:32 AM
40thblckgt's Avatar
Default Thinking of doing nitrous on my 07 GT, nitrous gurus only!!! HELP!
Well as the title says. So far I have a full exhaust (lt's back) and I just got a 95mm intake and tuner. I'm going to probabaly do ever n/a bolt on including cams. I had a blown GT before this and want to try out nitrous. What is the best kit out there for the money and what do you guys think of it?
Anyone know any AMAZING tuners in the virginia, pa, md area?
Besides what people say about nitrous backfire and such, with a good install and tune, isn't it 99.9% safe?
Thanks guys,
Brandon
Old Sep 5, 2007 | 09:43 AM
you should go with this kit if you have the money......http://www.nitrousexpress.com/Pages/3v_platesystem.htm
price is high but its the cleanest setup out there with the highest quality parts...just remember that you cant run a simple n20 system with a microswitch. Yours is gonna cost a little bit more to buy a kit that uses the fly by wire throttle control...
Old Sep 5, 2007 | 10:55 AM
40thblckgt's Avatar
Yeah, American Muscle has that kit in the 700's. I don't mind spending that much at all for a kit specific for the 3V GT.
Old Sep 5, 2007 | 12:22 PM
kjbuck2's Avatar
If your looking for a tunner in Pa you can head to SGS Automotive in Dillsburg. I have been there a couple of times and like the work they do. You can check out there page at http://sgsperformance.com/index.htm
Cheers.
Old Sep 5, 2007 | 04:17 PM
There are only a few kits made for only the 3v which is cool, but you can save money get a regular ford v8 kit and just get the fuel adaptor for the fuel rail. But ZEX,NX,NOS all have nice premade kits for 05+ cars.
Just dont be a ***** and spray a 50 or 75shot. It can take a 100-125 all day long. But before you do any of that READ!. Reading is your freind and learn as much as you can about nitrous before you buy any kit.
And nitrous backfires can happen with any kit but you can reduce the odds by correctly using your kit.
Old Sep 5, 2007 | 04:37 PM
Cheers.
I second these guys.....used to be called Kauffmans. They did my car.
Old Sep 5, 2007 | 05:08 PM
40thblckgt's Avatar
Thanks for the information so far guys!
How often would you say nitrous backfires occur when the nitrous is installed PROPERLY. Also, what can prevent it to a minimum?
Old Sep 5, 2007 | 06:12 PM
If its installed, working, and used properly you should never have a nitrous backfire.... That only happens when something has gone bad wrong. Get you a good window switch on there and you wont even have to worry about nitrous backfires. I was running 100 shot for 2 years like almost everyday spraying it and never had a nitrous backfire. That only happens if youre tune is really bad, wrong jets in, spraying below 3000rpm, or above the rev limiter.
What you want is a kit that is able to give quick nitrous and fuel atomization. One that mixhes the fuel with the nitrous evenly so it all flows well through the intake and doesnt puddle up in the bottom. Thats why I like these plate kits, because it sprays really evenly across the intake. Gives it a more even distribution of n20 into each cylinder. Nozzles work good too, but alot of times it allows for some "user error". People put the metal nozzle into a rubber intake. Seems harmless, but alot of times the nozzle is not positioned very well. The spray sometimes gets pointed into a bad spot. Ends up bounting off the sides of the intake and you might see 60hp on the left bank and 40hp on the right bank because more nitrous got to those cylinders before the other ones. That causes an unbalance with the engine rotation also which is bad for longevity. But dont think im downing nozzle kits, when installed correctly they can be just as good....
Old Sep 5, 2007 | 06:46 PM
40thblckgt's Avatar
Yeah, I'm almost 100% sold on the Nitrous Express EFI kit. I definitely agree that the plate system seems to distribute nitrous very efficiently! Will some nice n/a cams compliment nitrous?
Also, it seems like people are pushing close to 500 rwhp on a stock block with the 3V's (good tune of course), what do you guys think?
Old Sep 6, 2007 | 06:06 AM
By proper use i mean using the nitrous above 3,000rpms and dont hit the limiter with it either. Those two cause alot of the backfires you here about. The palte is nice, but i would look into more i dont know of anyone using it yet so you might wanna find someone who has it see what they think of it.
N/a cams will work good for nitrous as they will lean more on the intake side which means more nitrous will go in and more power. Main thing is read up my freind; i read for a good 4 months or so before i even looked into kits.
Old Sep 6, 2007 | 06:36 AM
Bwhipple's Avatar
In hibernation
I also recommend SGS for tuning. I just had my Procharger tuned there a few months ago. They did a great job.
Old Sep 6, 2007 | 11:03 PM
mpt_1962's Avatar
did you decide on shot size yet? Are you just running the NOS, or going to supercharge it like the old GT?
Old Sep 7, 2007 | 07:10 AM
40thblckgt's Avatar
I know with full bolt ons (cams, heads, etc...) I can get mid to high 300's out of her n/a. I think I'm going that route this time and throwing a 100 shot on!
Old Sep 7, 2007 | 07:15 AM
I thought you were sellin the car?
Go with the EFI kit, not the plate system. The plate system has a nasty lean spike. Get the Gen X2 kit with the window switch and all safety stuff. And of course a good tune and plugs.
Dont take it to Chris unless you want your graph looking like this.
Take it to Dave or Ed Clark.
Old Sep 7, 2007 | 07:16 AM
You say 100shot, but i know after awhile it will be turned into a 125 then a 150shot. It always does my freind
And holly crap thats an awful dyno sheet lol.
Old Sep 7, 2007 | 07:55 AM
mpt_1962's Avatar
what the hell happened on that dyno!? Thats what im doing with my Mustang. I'm going the N/A build, throwing NOS, and a 5 or 6 speed eventually. Just need to get the heads now, just bought the VT stage 2 cam. When is the VT stage 3 supposed to come out?
Old Sep 7, 2007 | 09:17 AM
Thats what happens when you bring your car to a ******* stupid tuner. Funny thing is, I was originally going to bring it to Kauffmans, but they said they could do it no problem. Im honestly surprised I was able to drive the car home from the shop. I never sprayed on that tune, and had to bring it to Ed Clark so he could fix it. The guys down there have even heard horror stories about that shop.
Old Sep 7, 2007 | 09:25 AM
mpt_1962's Avatar
that looks like it could have messed up the motor pretty bad, if not blown it. I hope the tuner im going to is experienced. There are cobras and some other Gt's that he has done and have posted up on their website. But im still nervous about my first dyno tuning.
Old Sep 7, 2007 | 06:05 PM
my plate kit worked awesome. Never any bad lean spikes....Im running 6 inch hard line from the solenoids to the plate.....it pulls all the way to redline
Old Sep 7, 2007 | 07:49 PM
40thblckgt's Avatar
Well thanks for the advice. Yeah Dan, I was going to sell, but my dad convinced me other wise. lol
I'm still torn on what kit to get, that EFI kit looks good, and want to read more into these "lean spikes" you're talking about. Never heard of that kit thus far creating that. If anyone else has specific information on the 3V EFI plate let me know!
Old Sep 8, 2007 | 07:57 AM
Well im not sure if you know what we mean by lean spikes so heres a quick once over.
Every kit once it turns on takes a massive hit to your fuel system (unless you run its own dedicated fuel system) this sucks up alot of fuel and makes a lean spike where the motor gets less fuel. On our cars as it pulls fuel from the rail its easy to see on a dyno with a wideband hooked up.
Some kits have worse then spikes then others. The 2v plate kit is know to have a really nasty one.
Old Sep 8, 2007 | 09:07 AM
mpt_1962's Avatar
have you researched the kit you are going to get? Decided on a shot yet?
Old Sep 8, 2007 | 01:23 PM
lol I never had any issues....
Old Sep 8, 2007 | 02:03 PM
The problem is the lean spike, just because you didn't melt a piston doesn't mean it doesn't have a nasty lean spike. Did you ever get tuned on the bottle only? i bet the a/f is nasty when it hits. Granted of course all nitrous kits do this, but the 2v plate kit is know for its nasty lean spike.
I know me talking badly about a NX product makes you angry though j/k
Old Sep 8, 2007 | 11:11 PM
mpt_1962's Avatar
what are the plates your talking about?
Old Sep 9, 2007 | 10:01 AM
if you want a good tuner....John Lund is a great tuner. he is on svtperformance but i forget his screen name. he uses evolution performance's dyno.
Old Sep 9, 2007 | 11:24 AM
hes talking about the NX 2v plate kit. I was initially referring to the 3v plate. Theyre actually completely different plate kits. The 2v plate is a simple plate with 2 bars going across the middle, one for fuel and one for nitrous. Fits under the intake elbow.
The new 3v plate is sweet. It has the solenoids built into the plate so you dont have to worry about mounting them. It uses jets just like any other kit. And it uses dual spray rings instead of bars that fit right behind the dual TB....
Old Sep 9, 2007 | 08:23 PM
40thblckgt's Avatar
Yeah, I'm pretty much sold on that kit. I've done a lot of research on it, looks awesome.
SeanStang
Aug 18, 2011 09:22 PM
mustangV6_04
49
Aug 31, 2010 11:50 AM
SPITFIRE
May 11, 2009 07:33 AM
shad0ws
Apr 25, 2006 12:06 PM
macs03GT
Aug 1, 2005 08:16 PM
