BALL JOINTS?
Old Aug 28, 2007 | 09:33 AM
LT1RUNNER's Avatar
Default BALL JOINTS?
Whuts up guys?! Need help!! Is the front suspension on a T-Bird the same or similar as a Mustang? My son has a 95 T-Bird and it has the 4.6v8 and the front ball joints are bad to the point where the car is not safe to drive. I know engines but nothing about front or rear suspension. I'll be doing the work myself and I need to know if there are any website I can go on to help me with the repair. If anyone knows then you help would be really appreciated. Thanks!!
Old Aug 28, 2007 | 09:39 AM
03DSG's Avatar
I would go to local parts store and see if the have a book on the various suspension setups. When I worked at murrays auto we had a TRW book the showed the suspension/ steering for every car. Also look up parts for the T-Bird and compare part numbers with those of a mustang. But I have a feeling not alot will be the same, but the ball joints might be. and ball joints are not super difficult, just a PIA.
Old Aug 28, 2007 | 11:12 AM
LT1RUNNER's Avatar
I'vr already looked up the ball joints in a Mitchell guied and it didn't show me enough information. If I was a little more suspension savvy then it may have been a good guied but I need something more detail and step by step. I'll check out Napa and see if they can offer a little more. Thanks for your help.
Old Aug 28, 2007 | 11:19 AM
What you can also do is to search for the part on Summit for the Mustang and the Bird. If both part numbers match, it's a safe bet they'll swap. If not, ask the parts desk at the dealer to see if the ball joints are the same for both cars.
Old Aug 28, 2007 | 12:05 PM
bossman302's Avatar
Welcome aboard LT. I don't know anything about changing ball joints but you may want to check out tccoc. c o m. It is a t-bird/cougar site and the guy/gals there may be able to give you the answer your looking for.
Old Aug 28, 2007 | 03:17 PM
LT1RUNNER's Avatar
Thanks Bossman! I found the site but unfortunatly it was limited on the "how to's" on suspension. If you know of any other sites please let me know. Appreciate all your help.
Old Aug 28, 2007 | 04:37 PM
bossman302's Avatar
On the mustang the ball joint is pressed in. You would have to find some way to press it out or take the control arm off and take it to a shop. I have no idea if the tbird is the same way. You would have to take a look at it.
I did some searching on the net and found that some ball joint are riveted on. If that is the case you can drill out the rivets
Below are some links I found that may help you. The first 2 talk about ball joints that are rivetted on. The third link is the instructions for Steeda's x2 ball joint. Hope this might help you out.
http://www.extremehowto.com/xh/artic...ticle_id=60227
http://www.popularmechanics.com/how_...e/1888732.html
http://www.steeda.com/directions/555..._balljoint.pdf
Old Aug 29, 2007 | 11:26 AM
LT1RUNNER's Avatar
Thumbs up
Now that's what I'm talking about. Step by step!! Bossman your alright. I owe lunch and a beer!! If your ever around the Phoenix AZ area look me up!! Thanks again!!!
NeedACobra
Jan 12, 2009 08:37 PM
theponyfactor
Jun 13, 2007 03:23 PM
theponyfactor
May 8, 2007 07:47 AM
tanuman
Feb 27, 2005 04:36 PM
Ozone89
Sep 16, 2004 07:22 PM
