The Parts Desk Need an OEM Ford Part? You've come to the right place.
Rear GT Honecomb
Old Aug 9, 2007 | 12:56 PM
krazypony's Avatar
Default Rear GT Honecomb
Hey a couple years ago when the Mach1's came out these were real hot items, Could someone tell me who might sell the Rear GT HoneyComb accessories?
Thanks!
Jeff
Old Aug 9, 2007 | 01:04 PM
El Diablo's Avatar
Old Aug 9, 2007 | 02:33 PM
krazypony's Avatar
DAMN!
There aweful expensive, wasnt thinking they would be that much!
Old Aug 9, 2007 | 03:40 PM
theycallmevirg's Avatar
or just get the vinyl version off ebay for 30 bucks. that's what i did and i think it looks better than the honeycomb
Old Aug 9, 2007 | 05:59 PM
krazypony's Avatar
can you post a close up picture of what it looks like? And maybe a link to someone that might have those for sale?
Old Aug 10, 2007 | 02:24 AM
R3dFire02's Avatar
I diddnt want to shell out the bucks for the honeycomb panel, and I wa fearful of my ability to put on the stickers and have it look good, so I simply masked off the back of my car and painted it. Granted I cant verry well undo it, but I like how it turned out. Ill try to throw up a pic later.
Mike
Old Aug 11, 2007 | 05:17 PM
Steeda97's Avatar
banzai
Gotta see this.
Old Aug 11, 2007 | 07:59 PM
Dave04Mustang's Avatar
if I remember right I believe mustangvsix painted his also and I it turned out great. If you use the search there is a thread somewhere in here about how he did it
Old Aug 11, 2007 | 08:04 PM
Here you go found it for ya
Originally Posted by mustangvsix;
You can do it yourself. All you need to do is go to autozone pick up some 800 grit wet or dry sand paper, A can of Duplicolor Gloss black or Flat Black automotive spray paint, Blue Painters tape, and a can of Clear coat. You will also need some newspaper.
To start, just give the back area a quick rinse to remove any large amounts of dirt
Tape off with blue painters tape the upper part of where you are painting. Basically run a piece of tape right by where the key hole and 3rd brake light is, so you dont' sand too high up.
Then take sand paper and a bowl of water, wet the sand paper, then start sanding the area you are going to paint. Rinse the sand paper occasionally to get the most life out of it. Sand until the clear coat(shine) is gone, and the sand paper is turning the color of your car.
Now wipe that area down with a dry cloat, until it is 100% dry.
Tape off the whole back end of the car with newspaper, and painters tape. Also be sure to tape off the licence plate lights, wouldn't want to be painting those.
Now shake the can of paint up well. Follow the directions on the can for how to spray it onto the car. Probably will need 3 good coats. After it dries for 30mins - 1 hour, apply the clear coat. Do 2-3 of these. Let dry for another 1 hour. Remove tape and newspaper slowly and carefully, so you dont' damage the edges of the paint. Wait 10~ mins or so between coats.
All done, good job!
I too was scared painting something on my car for fear of totally screwing it up, but if you take your time and follow what i said you can do it just fine.
Feb 21, 2007 03:33 PM
dmkx3
Mar 8, 2005 03:56 PM
