The Reference Section Just installed a new part on your car? Write up a How-To and post it here.
Spark Plug Change
Old Jan 5, 2007 | 05:45 AM
chatmanv6's Avatar
ChatmanV8
Default Spark Plug Change
Hey whats the easiest way to change the spark plugs on a 2002gt...I can do but i want to make sure i don't mess up anything or have to do anything thats not required..thanks for any help..Just did the seafoam to not as much smoke as i thought there would be but the car is smoother now...
Old Jun 6, 2007 | 10:04 AM
Bwhipple's Avatar
In hibernation
Its real simple. Do one at a time. Unclip connector. Remove the fastener holding the C.O.P ( coil over plug ) pull the coil and boot out. Unscrew the spark plug. Make sure the new plugs are gapped correctly. For stock iginitions .054 I believe. Re-install new plugs. Some people use a small piece of hose to install the new plugs this way you cant really cross-thread the spark plugs back in. then finish em off with the ratchet. Pretty easy huh?
Attachment 10961
Forget whatever else you see disconnected in the pic. You shouldn't need to remove anything else as I remember. I haven't ever just changed the plugs so I'm not for sure.
Old Jun 6, 2007 | 06:02 PM
http://www.dndgarage.net/sparkpluginstall.htm What you need to remove to get to the pass. side plugs will vary depending on year and model.
Sir Charles
Jul 29, 2007 09:57 PM
shad0ws
Apr 19, 2006 06:50 AM
Stang28
Apr 9, 2006 11:57 AM
Icefreezen
Oct 8, 2005 11:26 AM
zincougt
Sep 9, 2005 01:42 AM
