Drivers Side Power Window Not Working
Old May 17, 2007 | 02:33 PM
Steeda97's Avatar
banzai
Default Drivers Side Power Window Not Working
All the sudden both of the switches on my drivers side won't work. The passenger side window works perfectly. The fuse looks fine, and if the passenger side still works (the switch on the passenger side) then it can't be the fuse. My unlock/lock button works, but the two switches for the windows on my driver side won't work. Ahhhh, any suggestions?
Old May 17, 2007 | 07:50 PM
bout the same thing happend to me. except JUST the driver side window wouldn't work, i could unroll the pass. window from the driver side, but not the driver side window. i remedied this problem by waiting about a week and it started working again. idk what happend, but it's been working fine since so i'm happy :-) lol.
Old May 17, 2007 | 07:53 PM
bang on the door above the speaker hard; it has gotten stuck and has happened to a few people incluiding me.
Old May 17, 2007 | 07:58 PM
I have had the same problem. The copper contacts on the switch get oxidized and coated with armoral and stuff liek that. I got tired to cleaning mine, so I eventually replaced the switch assembly.
You can pull it out and take it apart. The contacts are a pain in the *** to clean.
Old May 18, 2007 | 08:03 PM
that's a good thing to know for future reference. i had plans of replacing my motor (thought it was that) which i heard from the mechanic i was gonna have do it that they were a pita. next time i'll clean the contacts, then bang on my door, and if that don't work....just stop goin' thru drive thru's lol.
Old May 19, 2007 | 08:57 AM
Stan's Avatar
Beantown Stang
I made a thread about this a week ago same thing happen to me hit the door panel hard behind speaker and press the button up ast the same time should fix the problem it fixed mine!
Old May 21, 2007 | 03:17 PM
Steeda97's Avatar
banzai
Yeah that wasn't the case so i just ordered two new switches. :-/ . 17 dollars a piece..
Old Jun 30, 2007 | 12:17 PM
TJeffer3's Avatar
hey im having the same problem with my convertiable back windows. Driver side wont let down, and the passenger side will quit working sometimes. So do I need to pull the door bezel off to clean the contact or do i just to to take the buttons off? And what did you us to clean them? I have a 2001 GT
Old Aug 28, 2013 | 04:48 PM
braden_russell's Avatar
Default thanks!!!!!!
a couple days ago i bought a 02 mustang. today the driver side window just randomly quit working (while rolled down) so i googled it to see if this was a common issue and sure enough i found this link.so i created an account here because i wanted to thank y'all for the help on knowing to hit the door panel by the speaker, it worked first try! just curious to know why hitting it by the speaker? wouldnt the contact tabs be right there by the switch? oh well, thanks again for the info! i just hope more people read this and don't get jew'd by auto shops.
Old Aug 29, 2013 | 07:09 PM
switch doctor's Avatar
The master switch is the most common switch to go out. http://www.switchdoctor.net 30 day return policy.
Old Jan 3, 2014 | 02:15 AM
GlendaAlvarez's Avatar
oh well see right after 6 years people have started replying .. is that any good ?
Tevida Side Effects
Old Feb 1, 2014 | 02:26 AM
KimberlyDiaz's Avatar
People are just mad in here. They don't see the date..simply start posting without even giving a second thought what is actually going on in the thread.
Old Aug 14, 2021 | 02:03 PM
Bantri's Avatar
Default This works
Had my driver side window stop working for several hours today halfway down (2017 convertible). Everything I tried didn’t work, but this... this did it. Hit a couple times, nothing, hit a bit harder and it started working again.
Acttacus
Dec 5, 2008 12:46 PM
Stan
Apr 23, 2007 10:27 AM
Cobra King
Aug 29, 2006 07:35 PM
PureStang
Aug 7, 2006 01:45 PM
burnsmustang
Jun 7, 2005 10:19 PM
