Faint coolant smell.
Old May 14, 2007 | 02:45 PM
Kains03GT's Avatar
Default Faint coolant smell.
Guys. When I'm driving around I get a faint wiff on antifreeze.Expecially when i get on it.Not over heating or even running alittle hot.Check the hoses,can't see a leak.No drops under the car when parked either.Any ideas?
Old May 14, 2007 | 02:50 PM
If the smell is strong inside the car could be a leaking heater core. If its from the outside of the car could be, any number of hoses have small cracks or manifold has small leak, gasket rips etc.... this is a tuff one to find the answer over the internet.
Old May 14, 2007 | 03:39 PM
x2 about the heater core
Old May 14, 2007 | 04:11 PM
Kains03GT's Avatar
I was thinking that too.But all heater cores I've dealed with they leaked into the cab onto the floor a little.Never looked 4 the heater core on the mustang.Is it passenger side?Whats the best way to get a look at it?
Old May 14, 2007 | 04:19 PM
4.6 Love's Avatar
You best to hope it's not the heater core as they are a pita to change....
Old May 19, 2007 | 10:43 AM
MOTT's Avatar
OUTCAST
Pray it's not a head gasket!
Old May 20, 2007 | 07:42 PM
Kains03GT's Avatar
How can you tell if its a head gasket?
Old May 20, 2007 | 08:21 PM
loss of coolant, puddle under car or maybe a few drips, burning the coolant (white smoke?)
Old May 21, 2007 | 02:13 PM
Kains03GT's Avatar
nope,none of those
Old May 21, 2007 | 04:03 PM
turn on your heat i bet it smells like like hot coolant once the motor is warm.
Old May 21, 2007 | 04:15 PM
Kains03GT's Avatar
I'll try it in the morning(too damn hot now..lol) And if it does smell like coolant?Is that the heater core?
Old May 21, 2007 | 04:27 PM
nope,none of those
really now?
Old May 21, 2007 | 09:48 PM
yeppers, the heater core doesnt all just blow ans dump coolant down. My f150 got a big crack and leaked it into the ducts and it smelled like awsome hot coolant till i bypassed the heater core. Good thing florida doesnt get cold often as i never bothered to fix it lol.
Old May 22, 2007 | 02:45 PM
Kains03GT's Avatar
Ok I turned heat on full...No smell...Has to be a leaky hose when it's under higher pressure under full throttle.And I'm not sure if I'm getting use to it because I don't smell it every time.
Old May 22, 2007 | 05:12 PM
hmm, this problem seems to be a sneaky sob...well you could get another person to give it a lil gas, get the rpms up there and look under the hood to see if ya have any leaks..and since they won't be acustomed to the smell, they might be able to point it out a lil better then you can since you've been around it for a bit now.
Old May 25, 2007 | 08:45 AM
jjandascog's Avatar
Might have to get a pressure tester so you can pressure up the coolant system to find the leak. I have on and they are very handy at finding small PIA leaks.
MattJ
May 10, 2007 01:46 PM
dsdaddy
Apr 8, 2006 12:23 AM
1Bad5L
Dec 13, 2005 05:32 PM
pneon99
Mar 29, 2005 01:06 AM
03 CENT.
Jan 18, 2005 08:56 AM
