hang exhaust proper
Old Apr 1, 2007 | 10:51 AM
SxyXc's Avatar
Default hang exhaust proper
i can't find a way to get them both to hang at an equal level without having my passanger side muffler be way to low to the ground.
how can i make em even??
right now i have it too were my pas side muffler won't hang too long and scrap the gound. in this pic though it was the way i got it.. my pipe hasn't moved positions much when i leveled out the muffler though
Old Apr 3, 2007 | 12:54 PM
swooshonln's Avatar
are those the stock hangers?
Where do you want your pipes to be? in your driver side position, or in your passenger side possition?
You would probally be able to start by looking at your hanger, were it looks like (for some reason, I can see under your car) that the drive side hanger is alot longer, or not seating properly on the ganger. CAn you take a picture of under the car?
Old Apr 3, 2007 | 02:04 PM
SxyXc's Avatar
i would like for them to be both as high as the passanger and later today i will take a picture and post it. but from the me looking at it. the rubber thingy that conects the exhaust to the car, on the driver side it is straight up and down and on the passanger side it is at a angle, but i will get thouse pics on here later tonight
thanks
Old Apr 3, 2007 | 03:52 PM
swooshonln's Avatar
if you look under your bumber at the piece, is it missing a bolt by any chance? I know my my 99 the rubber holder is connected to the frame with two bolts, sounds like it might be missing some bolts? (ie hanging loose)
Old Apr 3, 2007 | 04:00 PM
SxyXc's Avatar
Right side (drive side)
Old Apr 3, 2007 | 04:01 PM
SxyXc's Avatar
Passanger side
i want the passanger side to hang alittle lower from the bumper
ands the driver side to come up
Old Apr 3, 2007 | 05:02 PM
swooshonln's Avatar
im trying to see if I can see the problem....
How does that rubber hanger fasten to the body? If it sets on a nut that you can tighten, see if you cant lift the exaust up and then re-position the rubber stopper in the same place as the passenger side, and then tightning it down into a good position.
Or if you could take a picture of hte other side of hte stoppper I could maby figure somethin out.
It looks like so far, however, that either the stopper is out of position (either because it has shifted or missing a bold of some kind), or that it is broken, and allowing too much weight to hang off.
Old Apr 3, 2007 | 06:50 PM
SxyXc's Avatar
ok i got the best pictures i could. i wish the hangers where the same that they were on my 98 gt. they were easy to get too.
that was the passanger side. not a great picture but it is hard to get my big canon rebel in there
and driver best pictures i could get. sry
Old Apr 3, 2007 | 07:49 PM
swooshonln's Avatar
when comparing the two hangers, do you see a visual difference in any of the positions of either the hook holding the exuast, the rubber hanger, or the arhook connecting the rubber hanger to the frame?
Old Apr 10, 2007 | 08:11 PM
SxyXc's Avatar
ok soo i'm thinking about instead of worring is they look good from the back, in about 2 weeks when i get my o/r H-pipes just to buy dumps and do a dumped system, which is the best way to go on this, right after my flowmasters, or bring the over the axle?
Old Apr 11, 2007 | 05:38 AM
YOu dump them after the muffler. Be sure to angle them at like 45* angle towards the outside of the car so some of the exhaust gets out form under the car.
Old Apr 11, 2007 | 06:02 AM
SxyXc's Avatar
ok thanks
JackThe Ripper
Feb 6, 2008 09:23 PM
Nov 4, 2006 10:58 AM
whitethunder46
Oct 21, 2006 05:46 PM
cobra1923
Jan 24, 2006 01:45 PM
Jack The Ripper
May 6, 2005 12:22 AM
