Squeaky
Old Mar 31, 2007 | 06:17 PM
Default Squeaky
So, I replaced my belt and got rid of my old crappy tensioner. Now, when I start the car, I get a squeak until it warms up. The sound pulsates with each rotation of the belt and then after about 20 minutes is gone.
I think it is the belt because it goes away and not a pulley. How do I know? And, if there something I can do to cure the squeak?
Old Mar 31, 2007 | 06:44 PM
Use the crayon trick.........learned it from dustin, while the engine is running hold the crayon against the the belt
Old Mar 31, 2007 | 08:59 PM
Someone told me the same thing but using a lit candle so the wax will build up on the belt getting rid of the squeak.
Old Mar 31, 2007 | 09:06 PM
SxyXc's Avatar
i was told to use a bar of bath soap.. thats what my grampa told me to do..
but i guess they would all work. i know the soap does and i can see the crayon & candle working because they are wax
its wierd how many diffrent ways there are to fix one problem, and thay all work well too..
Old Apr 1, 2007 | 02:57 PM
I tried the crayon trick. The squeak went right away and then just cam eright back. Not I have blue pullies and a blue belt. Hopefully I just dis not screw myself over. I am having nightmares now of having to pull everything off and clean it - lol
I did not use much crayon.....not even a 1/16 of an entire small crayon. I just hope the wax won't cause the belt to slip. The **** will probably just wear off and melt under heat.
Blake
CCM
20
Apr 13, 2006 09:58 PM
yeayea0
Jan 28, 2006 02:23 PM
Badfish
Jun 10, 2005 05:38 AM
Mrktre02
Jun 2, 2005 06:17 AM
KawboyGT
May 8, 2005 08:12 PM
