What is this fuel pump??? duel pumps
Old Feb 25, 2007 | 07:38 PM
jdslyrbullitt's Avatar
Default What is this fuel pump??? duel pumps
I was going to install a SVT focus pump in my 01 Bullitt and discovered it has already been changed to a duel pumps. Does anyone know what I might have in this car?? The assembly cover had part number 2R3VAD, 9H307, Base, 6/24/03.
File Type: jpg
File Type: jpg
Old Feb 25, 2007 | 07:53 PM
9H307 is SVT focus pumps. Looks like it was already done for you.
Old Feb 25, 2007 | 07:58 PM
Default focus pump
is this setup better than the single green top SVT focus pump??????
Thanks
Old Feb 25, 2007 | 07:59 PM
Well considering you have double the flow of a single SVT pump, yeah its an upgrade.
Old Feb 25, 2007 | 08:02 PM
Default blower
My Vortec SQ is going to appreciate that
Thanks
Old Feb 25, 2007 | 08:12 PM
Wheat's Avatar
Those are actually '03 Cobra pumps. See if your tank has a small plastic reservoir inside, or a large steel one. If it's the latter, then you have an '03 Cobra tank too, big plus with dual pumps.
Old Feb 25, 2007 | 08:44 PM
according to the part number he gave, those are svt focus pumps.
Old Feb 25, 2007 | 09:25 PM
If you're running the stock GT/ Bullitt tank with dual pumps then you're running the risk of sucking the tank dry, unless it has been modified. But I dont recommend doing that. The best/ safest way to run two pumps is with the cobra tank.
Old Feb 26, 2007 | 05:33 PM
Wheat's Avatar
You may be right; I'm used to Focus pumps being green, and '03 Cobra pumps being purple. We typically get the Focus stuff from Motorcraft.
Old Feb 26, 2007 | 05:40 PM
Hmmm, my focus pump is green also.
Old Feb 26, 2007 | 06:50 PM
my focus pump is also green. But its either dual SVT's or cobra's or the steeda upgrade. Regardless you got a good fuel system so dont worry. Thats more then enough for the stock shortblock (assuming thats what your rocking).
Ok I just looked really fast and those part numbers pull up as Ford SVT Focus pumps. So you have duel focus pumps. Thats a pretty damn good setup fuel wise.
Old Feb 26, 2007 | 09:03 PM
Default cobra setup
I called ford today and the 9H307 stands for all ford fuel pumps.
the 2R3VAD cross referenced as the cobra pumps
my tank had 2R3Z9002AA which matches the cobra tank according to forum research
check out the pics of the baffles
looks like I am all set
Thanks guys
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Feb 26, 2007 | 09:05 PM
Default green SVT focus pump
looks like I will not be needing the focus pump I was planning to install
does anyone need mine for a fair price???????
Old Feb 27, 2007 | 06:02 AM
Wheat's Avatar
Man, that is a nice suprise! If only we all had that kind of luck! You're set, bro. And a BAP will take you to 550+ RWHP.
Old Feb 27, 2007 | 10:58 AM
Tell me about it!
Old Feb 28, 2007 | 04:24 AM
Bwhipple's Avatar
In hibernation
I've got $50.00
16
Oct 2, 2007 07:59 AM
Bwhipple
Jun 6, 2007 04:46 AM
Bwhipple
Feb 20, 2007 05:23 AM
Icefreezen
Jan 16, 2006 05:52 AM
Stangdude27
Jan 13, 2005 07:46 PM
