Nitrous need a little more info.
Old Jan 31, 2007 | 06:48 PM
cameltoe's Avatar
Question Nitrous need a little more info.
I've been reading a lot of post on here about nitrous and have a few questions of my own.
Lets say I had this set up. http://www.americanmuscle.com/niexfoefikin.html
with a nitrous express RPM window switch. With the RPM range set at 3500 and 5200 RPM with a 75 shot. Now to my question I'm pulling up next to someone ready to race. Turn on the bottle and purge the system. Take off good, shift to second then shift to third and miss what happens? Will it star to spay when goes up over 3500 then stop at 5200? When the RPMs are falling back down because of the over-revved engine what happens? I think that's it for now.
Thanks
Chad
Old Jan 31, 2007 | 07:39 PM
You would stop spraying (assuming you didnt lift the moment you know you arent in gear) because the window switch would stop it from spraying after 5200rpms or whatever you set it at. Thats the point of the switch.
Old Jan 31, 2007 | 08:14 PM
cameltoe's Avatar
Does it only spray the RPM ranges if its WOT? I mean what if for a split second it sprayed with no load on the motor from the miss shift? Would that be long enough to cause any damage?
Old Feb 1, 2007 | 06:24 AM
mustang46mod's Avatar
Just don't miss and every thing will be fine.
Old Feb 1, 2007 | 06:30 AM
If wired up correctly yes you car should only spray when at WOT and in the preset RPM rang you picked.
Old Feb 1, 2007 | 06:35 AM
cameltoe's Avatar
Thanks for your help Spike.
Old Feb 2, 2007 | 06:26 AM
No problem at all
mr triple six
Sep 10, 2007 01:26 PM
stanger00
Jan 16, 2007 10:44 PM
roushrider81
Jun 23, 2006 08:11 AM
Lightning247
Jun 25, 2005 08:02 AM
