question
Old Jan 16, 2007 | 08:53 PM
96gtstang's Avatar
Default question
Stock PI Heads w/ Stock PI cams
Cam Covers
Timing Chains, Timing Guides and Crank Sprocket
Front timing Cover
PI intake
in my eyes so far that looks to be all that i would need to do a PI swap under the hood...as far as a tune goes or w/e i imagine the tune that is in my car now (stock tune) will not work with those heads and cams..are their mail order tunes made just for this swap or would i be bettter off gettin the car on a dyno after it all gets installed...also if i were to do that i imagine i would have to buy a handheld tuner and take that to the dyno and they program it for me?
Old Jan 16, 2007 | 09:34 PM
The best way to go is to get the dyno tune, thats assuming the tuner is good. Youll get a better deal buying the chip or tuner from the shop thats tuning the car, in most cases.
Old Jan 16, 2007 | 09:43 PM
All you need is the heads, the intake, and alt bracket. Unless you have lots of miles or your chain/tensinor/tensioning arms are worn, those also can transfer over. As for and timing cover, if you use Romeo PI heads, then you can use the ones from your current set-up. However, Windsor heads require those two parts specific for it. Also, you need new head gaskets, bolts (get the ARP studs), balancer bolt (only if you remove it), timing/cam cover/intake gaskets (if they are damaged), and that should cover it.
Old Jan 17, 2007 | 04:57 PM
smg32208's Avatar
99blkgt
why would u bother? i thought u were getting a new car in spring
Old Jan 17, 2007 | 06:40 PM
96gtstang's Avatar
well thats what will most likely happen but i found a tight deal on the swap...sooo...maybeee
