What is Wrong With My Transmission? (*VIDEO*)
Old Jan 8, 2007 | 06:17 PM
eventer289's Avatar
Default What is Wrong With My Transmission? (*VIDEO*)
I have been told this is my throw out bearing. It does this when I put it in neutral and 5th gear when the transmission is cold, mainly on cold mornings and after it has sat for a while. It is quiet for a few seconds and then starts into this noise, kind of pulsing. The sound goes completely away after the tranny gets warmed up. Ideas on what this could be? I'm planning on a spec stage 1 clutch anyway, so hopefully this is only related to my clutch or TOB.
http://s24.photobucket.com/albums/c3...ansmission.flv
Old Jan 8, 2007 | 06:19 PM
dunno what it is but dont waste your money on a stage 1. go stage 2
Old Jan 8, 2007 | 06:25 PM
eventer289's Avatar
Is it worth the extra 100 if I am probably just going to be N/A with cams?
Old Jan 8, 2007 | 06:35 PM
yes its worth the upgrade. a stage 1 clutch is basically a stock replacement. but for the throw out bearing, go with a Ford OEM Throw out bearing. the Spec bearing seems to cause the chatter known to these clutches and the ford eliminates ths problem
Old Jan 8, 2007 | 06:41 PM
eventer289's Avatar
Do you have a stage 2? If so, how do you like it? How stiff is the pedal and is a firewall adjuster necessary?
Old Jan 8, 2007 | 06:51 PM
00PerfRedGT's Avatar
Its good to be blown...
To be honest I am not wasting my money on even the stage 2, I am going with the stage 3. I have driven a Camaro SS with head and cam making 450 rwhp and it had a spec stage 3 and it was fine, no stiffer than what mine is now. The other alternative is to go with a clutch and flywheel from a 2003-2004 cobra, the 11" with an aluminum flywheel. I might go the ford racing route...something to consider...and yes that is defintely your throw out bearing. For a bunch of different bolts and bearings go to latemodelrestoration.com they have pretty cool stuff.
Old Jan 8, 2007 | 08:14 PM
Stay away from aluminum, you'll have problems w/ it bogging from starts. Also, you can't compare the pedal effort from a Camaro to a Mustang since the Camaros had ahydraulic clutch likage.
Old Jan 8, 2007 | 08:37 PM
camaros are a lot lighter than mustangs anyways. different car, different tranny, different clutch setup.
irrelivant comparison.
Old Jan 8, 2007 | 08:42 PM
+1 and camaros are crap
mountainmust
Jul 11, 2016 08:05 PM
Steve@CJPP
Sponsors
Oct 30, 2014 06:56 AM
RCTrucker7
Jun 11, 2009 09:06 PM
Demetri X
Apr 23, 2009 08:16 PM
MattJ
Aug 18, 2006 09:21 AM
