May need an oil pressure sending unit...or worse.
Old Dec 27, 2006 | 06:06 PM
Default May need an oil pressure sending unit...or worse.
Randy, stang has been sitting since 11/1. I pulled it out just to run it, wash it, and put my new trickle charger on the battery.
To my amazment, I look at my oil pressure guage while the car is at idle and the guage is all the way to the left as in ZERO. I tap the throttle and it jumps up to normal. Sits there a while, then falls back off.
Now, I seriously doubt I have an oil pressure problem. No SES came on or low oil pressure light either. Car sounded fine and this event repeated itself about 10 times before it just stopped jumping and the guage read normal.
The guage was dropping off as if I had turned the car off. Does this sound like the sending unit is bad? Is there anmything I can do to verify? How can I be sure the pressure is good?
Looks like I am starting to amass a nice order. I still need the some pullies and a few other things, I wonder if I should just get an oil sender. I hear it is located by the oil filter.
Old Dec 27, 2006 | 07:50 PM
ernest russell's Avatar
Smile
The guage was dropping off as if I had turned the car off. Does this sound like the sending unit is bad? Is there anmything I can do to verify? How can I be sure the pressure i?
thats what it sounds like,its located at the oil filter a 13/16 wrench should do it,i would put something on the threads,teflon tape works fine lol
Old Dec 27, 2006 | 10:39 PM
Do those things just go bad, or do you think it could be loose?
Old Dec 27, 2006 | 10:46 PM
3V2000GT's Avatar
46MONSTER
before my engine blew, my oil guage was doing the same thing, come to find out the oil pump was bad, just thought you might want to know that
Old Dec 28, 2006 | 05:27 AM
1999 and up Ford cars and trucks wth modular engines have had oil pressure sending unit issues. thier is an improved sender, part # 6U5Z-9278-D we have plenty in stock if you need, price is $7.99 + shipping from us
Old Dec 28, 2006 | 09:39 AM
Sounds like I should not take this lightly! Thanks for the comments. Looks like I should replace the sending unit and even have the oil pump checked. Can't hurt and it is such a critical piece.
I wonder what is involved to check.
I have a call into Randy and I will see what he says and then order what I need.
Old Dec 28, 2006 | 09:47 AM
got your message, will call you inna' min
Old Dec 28, 2006 | 04:19 PM
As per our phone call, here is a picture:
Also, do you see the red strap?
Old Dec 28, 2006 | 04:27 PM
oops.....forgot the photo:
File Type: jpg
Old Dec 28, 2006 | 04:29 PM
Randy, keep in mind that I have a Novi2000, so the second line is for the oil to the blower. I don't know if this is the supply or the return line. I think it is the supply, correct.
Also, the red strap is disconnected. Take a look.
File Type: jpg
Old Dec 28, 2006 | 07:37 PM
I am not sure where the strap is supposed to go, but I believe it may have come from here:
This picture is just in front of the oil filter.
File Type: jpg
Old Dec 29, 2006 | 05:50 AM
well I see some issues.
1st is that red wire is a EEC engine to frame ground strap and SHOULD be hooked-up.
now from what I see on the oil filter housing is it IS a Windsor set-up that someone has already Tee'd into, so adding another "T" is not a good idea.
you'll either have to but a Romeo oil filter adapter on or delete the factory electric oil sender/idiot lite/gauge and install your mechancial o/p gauge in that port
Old Dec 29, 2006 | 10:08 AM
Randy...thanks for your time on the phone.
I forgot to ask you, where does that red strap get bolted? Do you see the phot with the missing bolt? Is that where it came from? Or, do I just go to the frame somewhere?
Old Dec 29, 2006 | 10:14 AM
never a problem, now ther should be a "stud" going thru the engine mount to the engine block, it goes on there wth a 8mm nut
Old Dec 29, 2006 | 11:10 AM
Randy....is this the spot you think?
File Type: jpg
Old Dec 29, 2006 | 11:15 AM
yeah, it can go there too.
Old Dec 29, 2006 | 12:34 PM
Could that be why my oil pressure guage is acting up? I wonder if it is not getting good ground and thus loosing power.
Old Dec 29, 2006 | 12:47 PM
sure, that is a possibility
Old Jan 4, 2007 | 04:41 PM
Randy, I got your v/m. I have been swamped and will call you tomorrow.
Old Jan 5, 2007 | 05:18 AM
ok, sounds good
JackThe Ripper
Mar 7, 2009 10:20 PM
sand1303
May 10, 2008 06:42 PM
Cruzang
Jan 14, 2008 07:50 PM
Jason24
Dec 6, 2005 01:23 PM
Icefreezen
Oct 12, 2005 03:20 PM
