New Product Comming Soon!
Old Oct 21, 2006 | 04:23 PM
Scott02GT's Avatar
Yeah, right
Default New Product Comming Soon!
Hey everyone, for those who do not know I am the designer and supplier of all the instrument panels American Muscle sells, including the SCT coin holder panels and the round cup hold nitrous panels. I am starting this post because American Muscle jut placed an order for my new product called the Power Pack 6.
It is basicly a power distribution center that installs like a stereo amp, and allows you to power six circuits up to 40 amps per circuit!.
The features include allowing you to power up via ignition switched power source, or manual toggle! It has independent Bosch type water proof relays and it's own Blade type fuse block!. This unit will allow even the most novice installer to supply power to just about anything you need from gauges to fuel pumps, oil pumps, full nitrous systems, lighting and more.
It wil cut installation time down from a few days to a few hours and make any install look clean and professional. It also causes NO DAMAGE to the OEM harness.
Here is a few pictures, they will be in stock by next week so if you have a winter project your starting this unit will make it an easy one.
I am here to answer any questions you might have. Here are some pictures, as you can see it is built to last, it features stainless steel stud terminals, aluminum casing with a composite, laser engraved face and sides. the chart you see is a wire run chart which tells you exactly what size wire to run for the current need in every scenario.
I desinged this myself and put a years worth of research into it make sure it is as easy as possible to install and use. You can see the rocker switches on the top, this is so you can switch each circuit from ignition switch (key on) to Manual toggle switched, incase you want to turn on a few circuits manually.
Seeing we are switching the relays, you do not need heavy wire for switching, and on the toggle switched option, your switching the ground! This means that when you hook it up, you just ground a wire anywhere, run it to a switch, then run it to the corrosponding terminal in the toggle option section and your instantly able to swith on anything up to 40 amps!
There is so may uses for this unit that I could go on all day, but instead I will let you all ask questions. The installation directions and advertisment flyer describing the details are both available to anyone who wants them, just ask.
Here is the best part of all, the cost The closest unit to this cost over 300 dollars and only does half of what this unit does, this unit, will only cost you 150.00! you basicly can supply power to every accesory you will ever install for less then a professional charges to install a radio system. and they come with a 2 year unconditional warrantee, and because I use common relays, after the two years say you burn out a relay, you yourself can open it up and replace them with a bosch type relay found at any auto parts store.
This is not chinese junk where you have a circuit board that frys and you throw it away, this unit is fully servicable by the customer. I also include my direcet phone number on the directions, so if you have a problem installing it you get me, they guy who designed it.
So like I said, ask away, WaterDR knows me and has used my products, he can vouch for the quality.
Old Oct 28, 2006 | 05:38 PM
I have known Scott for a few years and the quality of his stuff is top-shelf. I have used two of his devices on my car, and they are engineered extremely well (CST Switch and Nitrous Switch). I have not yet seen this product in person, but I am sure it is top-quality.
Old Oct 28, 2006 | 07:05 PM
hmm...
cool stuff... I'm trying to think of something to use it for... lol
Old Oct 29, 2006 | 04:28 AM
Scott02GT's Avatar
Yeah, right
Originally Posted by GREG@SN95
hmm...
Do you have aftermarket anything that requires power? That what this is for form fuel pumps to gauges, anything, this allows you to power up accesories with barely touching your OEM harness,
sand1303
Mar 28, 2010 08:55 PM
V6_Mustang_Power
58
Aug 29, 2008 04:53 AM
Nov 14, 2007 09:21 PM
Feb 28, 2006 12:32 PM
The Fox Body Authority
Jul 19, 2005 07:20 AM
